cold air intake
Old Sep 13, 2008 | 07:23 PM
mudlite's Avatar
mudlite
cold air intake
any suggestions on a cold air intake? plus and minus of any in particular?
Old Sep 14, 2008 | 08:29 PM
jwillyf150's Avatar
jwillyf150
Love my s&b CAI great throttle response and sounds cool. Increased mileage bout 1-1.5 mpg. Easy to install and looks great. Pics in my gallery.
Old Sep 14, 2008 | 11:51 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Volant CAI for the win
pics in my gallery
Old Sep 15, 2008 | 11:05 AM
98greensi's Avatar
98greensi
does the Volant have a dry filter? (no oil) what about the s&b?
anyone have any experance with the AEM brute force or the roush?
what i've read: the AEM is garented to provide the most hp, tq and flow or money back, the dry synethic materal does not flow as well as the cotten gaze but they design the systems to proived 4 times the amount of air needed. the system also has a heat sheild that when the hood is closed it's sealed so that it only draws air in from the fender. they have designed thier systems to keep the proper air/fuel mixture unlike some that create a lean a/f
AEM - Brute Force Air Induction System
edit:
the roush is pretty much identical for roughly the same amount of money only major difference is the tube.
ROUSH Performance: 5.4L Cold Air Intake Kit Detail
Old Sep 15, 2008 | 01:56 PM
pb34's Avatar
pb34
If you get the Volant CAI w/ powercore I know it is an oil-less filter. Like tylus I vote for the Volant. It has been great to me.
Old Sep 15, 2008 | 04:29 PM
FTL40's Avatar
FTL40
thats without a tune?
Old Sep 15, 2008 | 08:04 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
they call that a sealed box?
this is a sealed box. It didn't have the lid installed yet...that's why you can see the filter
Volant CAI vs. Roush CAI
it sucks are from the OEM hole in your fender...and then there is a 4"x3" (roughly) scoop on the bottom side directly behind the headlight that scoops fresh air as well.
Volant is very well designed, and problem free. The 04's initially had CEL's...well with pretty much every CAI...but that was due to their ECU fuel maps. The 05+ have a better ECU fuel map and the CEL's are pretty non-existant with 99% of the CAI's out there.
Old Sep 15, 2008 | 08:33 PM
pb34's Avatar
pb34
Here is a picture of the Volant with the top on:
Old Sep 15, 2008 | 08:53 PM
CLOTAGAMES's Avatar
CLOTAGAMES
Just installed new S&B-looks cool-sounds great-only problem-no way I am going to save gas when it sounds that cool when you put your foot in it.
Old Sep 16, 2008 | 10:14 AM
jwillyf150's Avatar
jwillyf150
No tune plan to get edge or gryphon in future tho.
Old Sep 16, 2008 | 10:16 AM
jwillyf150's Avatar
jwillyf150
Yeah I have trouble keeping my foot out of it too since I installed mine sounds great!!!
Old Sep 16, 2008 | 11:29 AM
Beechkid's Avatar
Beechkid
I have looked at every design out (IMHO), and while all share the same objective, fit, finish and the use of a dry filter (required IMHO) varies. Some produce a check engine light because of the air sensor location in the new unit. Given the cost, I built my own using existing OEM parts.
Based on my own flow testing and docs received from Ford & Wix, I concluded the following:
1. Flat panel filters can actually flow more cfm than cone style units if you analyze the turbulance or flow characteristics created after the entrance into the filter. I run a Wix HP series oem replacement unit (same series used in NASCAR).
2. The oem air intake manifold (the box located directly to the TB intake) is well designed with little gain to be had on a stock or lightly modified engine not turning over 5,500 rpm.
3. The pipe that feeds the air into the unit does have air flow restriction, most is seen at or below 35 mph and by design does not take advantage of potential gains from 35-70 mph.
4. Coldest air is located at a max height of 6 inches from the ground (from my old racing days) but is not a good location for street cars due to potential water and intake.
5. Ram air is still ram air.....
So I built a 1960's style ram air duct into the OEM manifold that replaces the intake hose. MPG gains are 16 mpg city, 13 mpg very heavy stop/go traffic, 21 mpg hwy (Lincoln Mark LT 4x2).
Throttle response is improved at idle and at 70 mph you can really feel a difference in terms of engine response.
Since I don't have time to go the track, we compared my truck to my cousins GMC which is the same year, but 4x4 and has the 8 liter in 0-60 accel test.
OEM to OEM air intake system: GMC beat the LT by 1/2 fender
My system to $600 GMC aftermarket CAI: Mark LT beat GMC by 6"
There are only a few of the CAI systems that are actually "engineered"- most are put together by what will install and how it looks- the do it yourself kits are probably just as efficient as 90% of what you can buy IMHO.
Old Sep 16, 2008 | 07:07 PM
fitz888's Avatar
fitz888
Love to see pics of that.
Old Sep 17, 2008 | 07:40 AM
f-150 on 22's's Avatar
f-150 on 22's
Volant with powercore filter. I have it and I love it, but if you do not like to hear your truck while driving do not get this intake.
Old Sep 17, 2008 | 02:59 PM
timberwolf980's Avatar
timberwolf980
I also agree with the volant have it also for my 08 great sound. gas mileage has increased also. A little on the expencive side because I also bought the ram air scoop for the box I love it....
