block heater
Old Oct 20, 2004 | 07:08 PM
hanklin's Avatar
hanklin
block heater
Hey buddy`s
Where the heck exactaly is my plug for my block heater?
The manual points to a spot near the drivers side headlite, I`ll be damned If I can find it.Thanks
Hanklin
2001 PSD
Old Oct 20, 2004 | 07:18 PM
mr_fixit's Avatar
mr_fixit
If you have one, its just to the right of the license plate if your looking at the front of the truck
Old Oct 20, 2004 | 07:24 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
All 99+ PSD's came with a block heater as standard equiptment. On mine it was tucked up above the drivers side tow hook, wire tied to a bumper bracket.
Old Oct 20, 2004 | 08:16 PM
Pikachu's Avatar
Pikachu
If you can't find the plug, the wire (should be) visible on the frame rail in the left front wheel well. As long as you can see it, you can trace it.
Old Oct 20, 2004 | 08:22 PM
RedTaurus94's Avatar
RedTaurus94
Mine's a '00, but:
Old Oct 21, 2004 | 07:09 PM
hanklin's Avatar
hanklin
Sorry guys I couldn`t find it,It`s probaly right in front of my face though. Should have attached a flair to it or something, thanks again
hanklin
Old Oct 21, 2004 | 08:39 PM
cookie88's Avatar
cookie88
FTE Emeritus
Try the other end of the cord. Directly above your oil filter you should see the large cord coming out of the side of the block. Try following it all the way up the frame.
Old Oct 21, 2004 | 09:16 PM
Pikachu's Avatar
Pikachu
Of course, it is possible that truck had the "cold weather delete" option. In that case, you would have neither the block heater nor the EBPV. Not likely since most trucks had both, but a remote possibility.
Old Oct 25, 2004 | 07:25 AM
hanklin's Avatar
hanklin
Thanks cookie 88, found it, as well as a bump on the noggin. After following it I was amazed that I didn`t see it before thanks
hanklin
