Plumbing Code rant
Old Oct 21, 2004 | 06:23 PM
85e150's Avatar
85e150
Yes, weak links in the water supply--our neighbor's wash machine hose busted, days of running water finally set off some alarm they had, and by this time water is running out of their garage door. The cops busted in and turned it off, but it resulted in new wood floors and a host of other issues.
How about those water alarms? Auto shutoffs? Is it still cheaper to rebuild the occasional house vs. equiping them all with that stuff?
Old Oct 21, 2004 | 06:49 PM
jskufan's Avatar
jskufan
If the truth be known, the washing machine supply lines probably create the same opportunity for a water disaster as the water heater. I have had the rubber type burst and when it happens, basically, water runs full force into your home. As a home owner, I suppose the responsibility for periodic inspection of all mechanical systems ultimately falls on your back. You can replace all supply lines with the metal braided type, inspect your water tank for leaks at frequent intervals and possible even replace it after a certain amount of time as a precaution. The pan and drain line are great if you can afford them. Lastly, if you're going out of town, turn the water off when you leave and at least you're protected while you're gone.
CougarJohn
Jan 24, 2017 08:07 PM
wezol5484
15
Oct 5, 2010 03:37 PM
ranger1999 Bob
22
Jan 4, 2010 01:58 PM
ghunt
35
Mar 9, 2009 01:59 PM
freirefishing
17
Nov 10, 2007 06:54 PM
