Bronco II Ford Bronco II
Rear Driveshaft Question
Old Oct 20, 2004 | 09:32 AM
7Yellow3's Avatar
7Yellow3
I found a guy parting out an 88 B2, and it has the good aftermarket driveshaft with the double cardan U-Joints. Everything I've seen on these shows the double joint on the transmission side and the single joint on the differential side. This one is the opposite, with the double joint at the rear. Which is correct, or does it make a difference?
Old Oct 20, 2004 | 10:51 AM
Help I M Stuck's Avatar
Help I M Stuck
mine is on the trans side..he might have put it in backwards.
Old Oct 25, 2004 | 07:03 PM
Big460Bronco
Guest
Posts: n/a
Talking shaft
The oneI had was also on the tranny side.
Old Oct 25, 2004 | 11:15 PM
RomerB2's Avatar
RomerB2
mines on tranny side also
Old Oct 26, 2004 | 04:40 PM
7Yellow3's Avatar
7Yellow3
Thanks for the replies, folks. A mechanic friend of mine said it made no difference, but I think I'll install it with the double joint on the trans side. Anybody else ever seen one the other way?
szotty
Oct 12, 2012 01:32 PM
lastclodstanding
Jan 25, 2012 07:32 AM
tao
Offroad & 4x4
Apr 9, 2011 10:52 AM
Blown 331
Oct 9, 2006 11:31 AM
lwinters
1978 - 1996 Big Bronco
Aug 9, 2005 04:27 PM
