98 Ranger 3.0L Error Code P0401
Old Nov 23, 2002 | 01:21 PM
hancockn's Avatar
hancockn
Post 98 Ranger 3.0L Error Code P0401
I am getting error code P0401. I had already replaced the EGR valve before reading any posts and that didn't fix the problem. It looks like the next step is to replace the DPFE sensor. I went to the Ford place and the parts guy said called it an EGR valve sensor and gave me the part.(part # 9J460) This part bolts on the front of the intake, has an electrical connector and two connectors for hoses coming off of the exhaust manifold. From one of the other posts, a guy said the placement of the DPFE sensor is on the left side of the engine behind the coil pack. Can someone tell me if the part I have is correct? If not, do you know the correct Ford parts number for the DPFE sensor?
Thanks,
Neil
Old Nov 23, 2002 | 02:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
You need an OEM manual for your truck.
I would suggest [link:www.helminc.com|Helm Incorporated].
Or you can try eBay, people say you can get one for $20 on CD.
I am not certain how well a Haynes or Chilton's manual would cover the emissions system, but you can try them.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Nov 24, 2002 | 02:40 AM
Diggr's Avatar
Diggr
Neil,
Had a similar Code P0401 problem with an '01 4.0L. When I figured out that it was still covered under the warranty I went to the dealer to check. The service writer told me it was likely the sensor and not the EGR. Said that the sensors had a tendency to get condensation in them and short out. On this engine the sensor is mounted on the left side valve cover but my Haynes manual shows a different looking sensor in their discussion. I can try to copy and scan this information for you if you want it. Let me know.
But, given that the problem is emission control related, are they not obligated to a 5 year warranty on that stuff. Also think you'll need one of those computer boxes to reset the error code.
Old Nov 24, 2002 | 07:11 AM
wildbillinva's Avatar
wildbillinva
that was me that said my haynes manual showed the DPFE sensor on the left behind the coil pack. i didn't know where it was. so i got one and looked around till i found it. (in front on the intake manifold) needless to say, i'm not happy with my haynes manual. the DPFE sensor replacement took care of my problem. the code was gone when i started my truck up. i had the positive cable off the battery for about 20 minutes .
wild bill in va.
Old Nov 24, 2002 | 05:30 PM
hancockn's Avatar
hancockn
Good, then it sounds like the guy at the parts counter gave me the right part. I have a code reader so I'll replace the part, reset the code and hope that it was the right sensor. Thanks for all the replies.
Neil
Old Nov 24, 2002 | 05:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
The Haynes manuals can be confusing at times. It is real easy to get confused about which model/engine/etc they are talking about. They also do make errors, -the editors are human. Haynes manuals generally contain wiring schematics which are helpful. Chiltons Manuals can get confusing and have errors also. I have both for all of my vehicles except the Starion which I have an OEM manual for.
You should also be able to clear the codes by disconnecting the battery for a few minutes. This method wipes out your stereo presets and engine optimization factors tho:-(
Old Dec 3, 2002 | 10:00 AM
fordlvr25's Avatar
fordlvr25
i have a 99 ranger, and was getting the same code, i narrowed it down to the dpfe, changed the part and the code has not come back. the part has been changed from being aluminum which was on the truck and it is now made of plastic with a different desing. So i believe that i have fixed the problem with the engine light.
Old Dec 3, 2002 | 10:15 AM
hancockn's Avatar
hancockn
I replaced the dpfe sensor this past weekend and cleared the codes. So far it hasn't come back. Thanks for all the replies.
Neil
Old Dec 3, 2002 | 02:11 PM
tbolt 460's Avatar
tbolt 460
kevinjrgaston
2004 - 2008 F150
Oct 26, 2013 04:22 PM
confusedranger
Aug 12, 2010 07:14 AM
10fords
Aug 30, 2007 11:16 AM
tweb
Modular V8 (4.6L, 5.4L)
Feb 10, 2004 12:55 AM
bereal
1997 - 2003 F150
May 30, 2003 11:01 AM
