Tapping noise
Old Oct 19, 2004 | 10:16 AM
LiveFast's Avatar
LiveFast
Question Tapping noise
I have a 98 Ranger and it makes a tapping noise all the time I took it to a guy and he listen to it and told me it was afuel injector tapping does anyone if this could be true or what it might be and it dont sound like a lifter the trucks only got 70000 miles on it.
Thanks, Livefast
Old Oct 19, 2004 | 12:02 PM
mizzleman's Avatar
mizzleman
The fuel injectors will make a tapping sound. If you use a mechanic's stethoscope and put it to each one, you'll hear it loud and clear. It will sound like someone's hitting an anvil with a hammer. If you're not sure that's the sound, you can use the stethoscope to probe around.
Old Oct 19, 2004 | 01:45 PM
PatG's Avatar
PatG
OR as I did as a teenager, use a cut off broom handle. One end on the part you're listening to, the other in your ear! Believe me, it works.
Old Oct 21, 2004 | 09:33 AM
LiveFast's Avatar
LiveFast
Alright I will try that and see.....
Thanks, Livefast
Old Oct 21, 2004 | 12:22 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Same thing works if you use a long screwdriver up to your ear........... uh just in case it has to be said out loud........ put the plastic end up to the ear, not the other end. This way you get to keep your broom.
Old Oct 26, 2004 | 10:17 PM
shawonzo1's Avatar
shawonzo1
Smile Gas quality may be an effect
In my 2000 3.0L V6, I have noticed the "clicking" under load. According to the forums, this is a common noise associated with the 3.0 Vulcan motor. I contend that by changing where I have fueled up, what type of octane rating, and also the usage of injector cleaners and/or additives is directly correlated to the frequency of you the driver noticing the clicking that I've described above.
Here's what I've noticed so far in 91,000 miles:
1. 87 octane makes the noise, no matter what gas brand I purchase. Some brands cause my truck to create more noise than others.
2. The use of 89 octane significantly lowers the clicking/pinging/knocking noise.
3. The use of the fuel system cleaner named "BG 44K" eliminates the noise for about 5 tanks of 87 octane. It (the noise) eventually creeps back into the fray.
4. The correct proportional use of Marvel Mystery Oil in the fuel, no matter what octane or brand, eliminates most if not all of the noise when in use.
Hope this empirical evidence works... but remember, every FORD is different.
Experimentation, like what I've done above, is the key. Kinda like "bonding", ya get to know your truck better!
Shawn
Old Oct 27, 2004 | 07:51 AM
LiveFast's Avatar
LiveFast
Where can I get some BG 44K cleaner, and I use 93 octane because I used a Hypertech power tuner and thermostat,and thats what I have to use..
Thanks, Livefast
Old Oct 27, 2004 | 07:16 PM
shawonzo1's Avatar
shawonzo1
Here's their web address:
www.bgproducts.com
search from there. My local Toyota dealer carries the product. I pay about $17 a can...
Shawn
muddhogg
2004 - 2008 F150
Apr 21, 2013 07:59 AM
LiveFast
Oct 4, 2004 07:00 PM
LiveFast
Oct 2, 2004 04:25 PM
LiveFast
Jul 19, 2004 08:48 PM
LiveFast
15
Jun 7, 2004 07:14 PM
