Low Oil Pressure
Old Mar 6, 2004 | 06:26 PM
Corbin18's Avatar
Corbin18
Low Oil Pressure
I have a 1989 Bronco with the 351 and the c6 trans. I just did intake manifold and valve cover gaskets. driving home I lost oil pressure. I only drove maybe 2 to 3 miles with no oil pressure. I am thinking it is the oil pump is clogged because there was alot of junk in the engine. My question is do you think I could have hurt anything or will i be ok just replacing the oil pump. Also the bronco has 140k miles on it. Thanks for any help.
Andy
Old Mar 6, 2004 | 07:44 PM
RichardMaerz69's Avatar
RichardMaerz69
I would take the distirbutor out and check the rod ,if it's twisted I'd check the oil pump,if not the wire could have popped of, or it could be your sending unit.
Old Mar 6, 2004 | 08:01 PM
Slade901's Avatar
Slade901
I would put 1 quart of Gunk Motor Oil Flush first, start the engine for 5 minutes. Drain the oil and put a new oil filter and oil.
catpwr1
Jul 21, 2012 12:20 AM
simsbud
Apr 20, 2012 11:25 PM
acourt
1997 - 2003 F150
Mar 22, 2006 06:20 AM
andy_547
Jan 9, 2005 11:04 AM
V8 Andy
Oct 21, 2004 12:57 AM
