Help! Code 433 And Engine Dieing!
Old Oct 18, 2004 | 04:31 PM
chspyder's Avatar
chspyder
Question Help! Code 433 And Engine Dieing!
I get a code 433 Cam shaft POS sensor error or problem and the truck just quits, lights are all on, and the radio dosent miss a beat. I have a new syncornizer as ford calls it, is this what I need to repace?
Jt
Old Oct 18, 2004 | 06:00 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
PO340? this is the code for CPS circuit failure. Closest one I could find to "433"
The best bet is the cam shaft position sensor "CPS". Around $80 bucks at an International dealer. Simple install. I believe it may also be called the syncronizer but am not entirely sure. CPS fixes a lot of woes.
Old Oct 20, 2004 | 11:20 AM
chspyder's Avatar
chspyder
I have a revised Ford one I just bought. I have not installed it, the truck has been fine since that day???
Puzzled.
Also how is the easiest way to get to this?
Jt
Old Oct 20, 2004 | 08:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The P0344 is CMP Sensor Circuit Intermittent, which pretty much sums it up. I found the best way to attack it was with a deep well 10mm socket from underneath the truck.
Old Oct 21, 2004 | 11:43 AM
chspyder's Avatar
chspyder
Do I have to remove anything or can I get to it just straight, I can see the wire loom goging torwds it, but not the bolt
Jt
Old Oct 21, 2004 | 04:02 PM
chspyder's Avatar
chspyder
I am trying to look for an easy to get to it
Old Oct 21, 2004 | 04:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
I don't remove anything. Some say that they had better luck by first removing the serpentine belt, but I did not have any difficulty. The bolt is on the top side of the bracket, directly above the sensor. Once you get your head at the correct angle to see it, you shouldn't have any problems reaching it.
Old Oct 21, 2004 | 05:02 PM
jamesj's Avatar
jamesj
sOMEONE GIVE THE ADDRESS FOR THE IH DEALER that sells the camp for $ 80.00. I live in San Diego, the local IH dealer wants $125.00 + tax. I figured $80.00 + shipping of approx. $ 10.00 = $ 90.00. Still a bargain. Thanks for the reply.
Old Oct 21, 2004 | 05:18 PM
cookie88's Avatar
cookie88
FTE Emeritus
That would be nice. I paid $100.04 out the door for my spare CMP, but it was still well below the Ford dealers cost.
BackWoodsGuy
May 15, 2011 08:35 AM
1969Highboy
30
Mar 23, 2009 11:18 PM
68FE390
22
Oct 13, 2007 01:21 PM
JCA433
New Member Introductions
Jan 16, 2007 01:44 AM
Logical Heritic
Ford vs The Competition
45
Sep 9, 2004 08:43 PM
