Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
torque wrench
Old Oct 18, 2004 | 04:21 PM
art_org's Avatar
art_org
torque wrench
I'm getting ready to replace my leaking pinion seal on my 99 f150 2wd
any suggestions on where i can barrow / rent/ buy an inch pound torque wrench in houston
also does any one know what size the pinion nut is (i think it is bigger than my largest 19 mm socket)
thanks
A
Old Oct 18, 2004 | 05:33 PM
maverick man's Avatar
maverick man
i have an inch pound that i bought at sears. i use it for small engines and transmissions.i think the one i have goes up to 250in lbs. it was something like $59 i think. not too expensive for something you don't use alot but its a good quality wrench. hope this helps.......
Old Oct 18, 2004 | 05:46 PM
68 351 bronc's Avatar
68 351 bronc
for that pinion seal you don't need a torque wrench, you need a good 1/2 inch drive air impact wrench. Rattle it down until you take the play out of the pinion shaft. If it's leaking it is probably because it is just loose or you have a bad pinion bearing. The crush sleeve is the culprit. 8.8s are absolutely notorious for this. You are suppose to replace the crush sleeve every time but there is no way your going to collapse it without an impact wrench.
Old Oct 18, 2004 | 07:18 PM
woodzracer's Avatar
woodzracer
Talking torque wrench
Check with Harbor freight either in your area or online, They have pittsburgh torque wrenches for $12.00 in ft/lb or $18.00 for inch lb. I have been told they are just as accurate as craftsman and carry a lifetime guarantee
Old Oct 18, 2004 | 07:35 PM
Fair 96's Avatar
Fair 96
Autozone rents tools try there..
Old Oct 18, 2004 | 07:37 PM
Fair 96's Avatar
Fair 96
By the way it is free at Autozone if you bring the tool back in one piece...
Old Oct 19, 2004 | 08:10 AM
art_org's Avatar
art_org
if its the crush sleeve or the berring, let me guess
i will have to pull out the diff to replace ????
not sure i am ready to tackle something of that difficulity woried about re installing the diff and aligning
is there a way to tell if it is just the seal
it just starting seeping fluid, not even enough to make a drip yet
the truck has 120k high speed high way miles
no towing
would like to get atleast 30k miles more without having to mess with this again
A
Old Oct 19, 2004 | 12:02 PM
FordPerf300's Avatar
FordPerf300
This is an easy way to do it, Mark the yoke and the pinion nut with white out or a paint pen or whatever (draw a line from the nut to the yoke). as your removing the nut count how many complete rotations it takes to remove the nut. Replace the seal and clean the threads of the pinion and the nut. apply blue thread locker and reinstall the nut the same amount of turns till it lines back up with the line on the yoke.
Old Oct 19, 2004 | 12:41 PM
Violjohn78's Avatar
Violjohn78
inch-lb is for setting the preload when tightening the nut back up. as far as renting an inch lb beam/dial type torque wrench i haven't found anyplace. i've found in-lb's dial type on ebay and i know napa has beam type in-lb torque wrench for about 65 dollars. The nut is 1 1/16. I will be swapping gears and putting in an LSD so i've been looking for all the tools i need. Those are the two sources i've found. You will prob be ok just marking location of nut on the pinion. Plus you'll want to put some silicone on the splines in the yoke just to prevent additional fluid leakage.
