I can't find a serial number close to the ones above. The only thing I can find is "oil reservoir assy" and those numbers don't look anything like the ones above. I did find a label on the driver's side valve cover that has an mfg date of Mar 19, 1999.
What is the serial number stamped on your engine? It is located either on a label on your valve cover or definately stamped beside the oil filter base on the engine block.
