Gauge Questions
(Well trans temp is not hooked up yet. That is a question for another thread)
My question is what should my egt, boost and Trans read normally. And what are the danger zones. I mostly tow with the truck.
I have a AFT Intake, Custom 4" To 5" Exhaust and running an edge evolution programer.
Safe operating temp depends on the location of your EGT probe, pre or post turbo. Mine is pre turbo. A post turbo position would give cooler readings, up to 300 degrees cooler has been reported. The best place to locate the probe is a point frequently argued here. Any way pre turbo is a more accurate reflection of the actual temp of the gasses leaving the cylinders. when the temp in the cylinders get to 1200 bad things start to happen the biggest potential is melting pistons (around 1350 I think) and burning valves. I try very hard not to allow temps to excede 1150 (just back off a little) and I dont like to run to long over 1000.
Boost is more a function of what all mods you have installed. However it is possible to overboost and that will cause some undesirable things to happen to head gaskets etc.
I know the newer trucks will hit a point (around 30 psi) where the pcm will defuel the engine to prevent damage. There are ways to overcome the overboost problem but they are quite expensive, only the super high performance guys do them.
Tranny temp is straight forward keep it under 200. If it starts to get to hot pull over and let it cool down.
5.7
How about 7.3 sorry that was a total typo.
