International number for 99 PS Turbo #5 injector
Can anyone tell me what the International truck P/N for #5 injector is or where I can find it. My local Int. guy says he can't cross reference.
Thanks! |
i can try if u give me your engine serial number.
I understand there are two different engines. Can you give both of them? I think that could help everyone out.
Ford : Before engine serial #375549 Serial #375549 and above International: Before engine serial #375549 Serial #375549 and above Thanks |
I can't find a serial number close to the ones above. The only thing I can find is "oil reservoir assy" and those numbers don't look anything like the ones above. I did find a label on the driver's side valve cover that has an mfg date of Mar 19, 1999.
Thanks in advance! |
What is the serial number stamped on your engine? It is located either on a label on your valve cover or definately stamped beside the oil filter base on the engine block.
