Flywheel/Starter
Old Oct 18, 2004 | 03:44 PM
MustangGT221's Avatar
MustangGT221
Flywheel/Starter
I have had a 302 in my truck stock, and I recently purchased a new starter for it. The truck also had a M5OD transmission. I have now removed that 302/M5OD and am putting in a stroked 351 with a ZF. The 351 uses a different flywheel than the 302, but I was wondering how many teeth are on that flywheel? I might return the starter I bought because I can get a hi-po ford racing one for about the same price. Therefore, I need to know how many teeth are on that flywheel so I get the right starter. Also, is that 302/M5OD starter able to be used on the 351/ZF? If it fits I might use that instead of a ford racing one. Any info is appriciated.
Old Oct 19, 2004 | 11:07 AM
loudfords's Avatar
loudfords
I believe the starters are interchangeable, the only difference between the flywheels is the imbalance weight. You can just overlay the 302/M5OD on the 351/ZF flywheel to confirm. (unless the trannies are still bolted to the engines, of course )
Old Oct 19, 2004 | 10:17 PM
Steve's Beast's Avatar
Steve's Beast
Exclamation
Sorry for junping into you thread MustangGT221 but I would like to know how to make shure the imbalance weight is at the right spot when the flywheel is bolted on the crank. Anybody????
Thanks
Steve
Old Oct 20, 2004 | 10:25 AM
gatesj's Avatar
gatesj
It should only bolt one way. The holes look evenly spaced but if you seat it against the back of the crank you'll find you have to spin it to make them line up. It only goes on one way.
Old Oct 21, 2004 | 06:48 AM
Steve's Beast
Thumbs up
Gatesj
Your a good man! That was bugging me for a while. I am going to store the 88 460 untill I need it. I am going to use the 76 460 in my f250, just have to find a neutral balance flywheel, and a clutch and pressure plate to mate up with my Zf 5speed.
Thanks!! Steve.
ArdWrknTrk
130
May 21, 2021 11:45 PM
chuck123
New Member Introductions
Aug 5, 2008 11:43 PM
Psyte
Engine Swaps
Mar 14, 2006 02:39 AM
brychar
Jan 11, 2004 10:47 PM
heybrent
1978 - 1996 Big Bronco
Sep 25, 2001 10:56 AM
