302 on long trips?/ towing capability
Old Oct 18, 2004 | 12:22 PM
electricsheep's Avatar
electricsheep
sorry, another question... I'm gonna be moving in a couple weeks down to florida from PA. its going to be a 1000 mile drive. my truck is my only transportation down there. its a 90 f150 with the 302 with around 106K, its running, but i'm just a little paranoid that it wont make it all the way down there. what would you guys check out and replace before making that long of a trip? I also have to fit alot of stuff in the back, which will weigh me down a lil. do you think its smarter to just rent a trailer and keep the weight off the back of the truck? hows the 302 do in towing?? sorry bout so many questions, i just dont want to break down in georgia in the middle of no where, ya know? any pointers would be really cool. thanks alot.
Dan
Old Oct 18, 2004 | 12:27 PM
andym's Avatar
andym
Check all the hoses and belts. Carry your tools in an easy-to-get-to place in the truck. I drove my truck from Buffalo to San Francisco last year, and it had given me years of reliable service. I get to Des Moines, and the alternator dies. I wound up changing it in the parking lot of a motel in the dark. And it was about 20 degrees that night. Not fun.
I'd also seriously think about a AAA membership.
Old Oct 18, 2004 | 12:56 PM
electricsheep
hey hey hey... i just remembered. I'm also having a problem with my heat gauge. It's telling me i'm always running cool. it doesnt even get close to the N on the temp gauge. I replaced the thermo stat ( that was a pain in the @$$) and i also replaced the coolant temp thingy, the gauge that lookes like a sparkplug sitting right next to the thermostat.
BUT, i'm having no luck. Im just concerned i wont be able to actually tell how hot i'm gettin on this long trip. any pointers?
Old Oct 18, 2004 | 01:02 PM
68torino's Avatar
68torino
An aftermarket set of gauges are cheap insurance. I don't like the lie-o-meter oil gauge I have on my F250 351. I'll be putting gauges on soon to verify what my motor is doing. If my pressure is actually low I'll put in a pump.
Old Oct 18, 2004 | 02:14 PM
electricsheep
see thats what i'm worried about. my oil pressure reads low too. i just dont know of a way to check my engine temp and oil pressure besides the dash gauges without spending alot of cash.
Old Oct 18, 2004 | 02:19 PM
cliffrwarren's Avatar
cliffrwarren
Here's a cheap insurance tip even if it doesn't appear to fit your situation
- radiator cap.
I had the problem on my 1991 where the coolant would boil in the overflow
tank after a drive. I replaced the radiator cap with a $4.00 NAPA cap. No
more boiling coolant! (It was fresh coolant, and a new radiator by the way...)
Hard to believe that the shop would sell me a new radiator with the old
cap. When those caps get old, they don't allow the cooling system to work
properly. Regards, Cliff
Old Oct 18, 2004 | 03:55 PM
pfogle's Avatar
pfogle
With only 106k on the clock the truck is just barely broke in. We tow a loaded box trailer almost daily with our 88 club wagon with almost 300k on it.... I wouldn't worry about it.. The gauge is an idiot light, it stays in one spot unless the voltage in the dash chagnes. It only needs 7psi to read "normal". Our '88 carries 65psi idle, hot, in gear...... but the gauge reads almost on the L.....
Old Oct 19, 2004 | 04:50 AM
wag53's Avatar
wag53
Hey, my '90 f150 has 145k on it (302, aod, lariat) and we have towed our camper to Daytona and Talladega several times with no difficulties. Just check it over close and again on the road and should be good.
Old Oct 19, 2004 | 09:26 AM
Blue94-302's Avatar
Blue94-302
If she's running good now, I would not worry about making the trip. Change your oil, Check your coolant and Trans. fluid, check your belts and hoses, load the truck and take-off. She'll do just fine.
Old Oct 19, 2004 | 02:28 PM
alkazoo's Avatar
alkazoo
probably wouldnt hurt to stop at your local catholic gift shop and pick up one of those dashboard madonnas,,doesnt hurt to have the allmighty ridin with ya on your trip!! lol..ok just kiddin...Youll do fine,,,like previous post indicated, check out all fluids and rubber and head on out....have a safetrip.
mine: 93 ford f150 xlt 4x4 119kmiles.
Old Oct 19, 2004 | 02:35 PM
MustangGT221's Avatar
MustangGT221
I took a 72 winnebago that was sitting for 4 years...started it up...drove it home...fixed a couple of things on it...drove it around for a few weeks here and there....adn took it to MD (from MA). Had no worries about it breaking down or anything, even though I wasn't even totally sure if the alternator was charging the battery heh. Ya can prepare but...usually you don't have what you need anyway. I wouldn't bother renting a trailer...the truck would have a harder time (now has to pull the weight of a trailer as well). Just load it up and hit the streets
Old Oct 19, 2004 | 03:40 PM
MemOrex's Avatar
MemOrex
We've gone on 4 1000 miles trips with the truck loaded all to the top. 3 of those times the truck had over 100k miles. Its at 150k now and still running great. Just check fluids and belts, etc... As for the temperature, just one time the Gauge went on the 'N'.
Old Oct 19, 2004 | 05:03 PM
MustangGT221
Honestly, a 1000 mile trip like I had to MD (both ways was over 1000mi), is the easiest 1000 miles ever. I probably hit the brakes 30-40 times the entire trip lol.
Old Oct 19, 2004 | 05:42 PM
electricsheep
sweet... i was thinking a trailor might be just a little too much. crossing states alone is gonna be an adventure. never went that far alone, not knowing what to expect when i get down there. its gonna be fuuun.
by the way, anyone know the working situation around Florida. if nothens in florida, i might head back up the coast to SC or something. The Ocean's calling me. construction worker looking for work here. speciality is electric, but i can bang a hammer as good as the next guy, ya know.
fordman19762003
2004 - 2008 F150
Jul 23, 2012 09:32 PM
TheTowingCowboy
Feb 22, 2010 03:07 PM
dakota-boy
May 28, 2009 11:17 PM
Mark250
20
May 26, 2008 09:54 PM
bgblktruk
1978 - 1996 Big Bronco
13
Dec 26, 2005 12:56 PM
