Sponsored by: Real Truck
Disconnecting battery
Old Oct 16, 2004 | 08:08 PM
Sparky04SD's Avatar
Sparky04SD
I'm in the process of installing additional switches for various aftermarket items and will need to disconnect battery to install an additional 2ga. 12v feed wire to a 8 circuit fuse block and a 2ga. for my 12k winch. If I disconnect the battery, will it cause any problems with the truck? I know about the stereo loosing it's memory but anything else to worry about?
Old Oct 16, 2004 | 08:11 PM
99f350sd's Avatar
99f350sd
normally no but the best way is to buy one of those 9volt gismo's that plugs into the lighter port to keep the computer memory hot.
Old Oct 19, 2004 | 12:22 PM
F-Deuce50's Avatar
F-Deuce50
You have to disconnect battery every time you mess the car. (maintenance)
cadunkle
Oct 17, 2016 08:56 PM
ZooDad
All Things Towing
Jul 25, 2016 07:06 PM
sccamper
Mar 18, 2013 05:03 PM
TheKirbyMan
15
Dec 5, 2010 11:26 PM
TheKirbyMan
'80-'86 FAQs (Frequently Asked Questions)
