Blower motor relay
From alternator: 37.5A
4ga off batteries to solenoids/distribution to all load: 33.1A
Yellow to cab: 22.88A
Blower motor: 14.09A
130 amp 3g... Way overkill, seems like the 42A factory alternator was adequate and a 65 amp 1g certainly would be sufficient. Though the 3g can keep up with any normal or reasonable additional load in these trucks at idle where a 1g or 2g will not. Wish I had one of those mondo amp load test resistors to check max amps at idle and RPM.
I may do the blower relay this weekend. Should be quick and easy since wires are right on pass inner fender where my fuse/relay box is. I will measure voltage drop at the blower before and after. I'll likely do 12ga wire, one size larger than required for the load. Should solve the voltage drop to the rest of the cab and hopefully get a bit more CFM from the blower.
I hooked up some short clip on test leads and blower speed didn't seem appreciably different, though it turns out they are only 18ga but have some pretty thick insulation which fooled me, so there was well over 1v drop through those. After that test I'm not expecting any huge gains, but will proceed to keep from overloading the old cab wiring and maybe get a minor increase in performance. I will use 12ga off the relay as it's only going a foot or two and I've already measured the load at 14.xx amps. Trying to figure out how I want to do the wiring to keep it clean and tidy so I'll ponder than for a bit then whip something up.
Got back to this and got it done. I ran 14ga off the factory hot into the trigger for the relay, only went larger than necessary because it was easier to connect to the large factory wire. Did a unsealed butt connector on that crimped and followed up with liquid tape and heat shrink. 12ga from the relay to blower motor +12v, reusing the existing connector I pulled off the factory plug and crimped on the new wire. Used a Metripack 280 2 conductor plug to go to the fuse/relay box for easy disconnect. Heat shrink on the wires between plug and box and plug and blower motor.
New measurements:
Volts at blower, high: 13.84v
Volt drop blower high: 0.31v
Volts at blower low: 5.76v
Volt drop blower low: 0.07v
Amps high: 17.85
Amps low: 4.83
There is still room for improvement when I get to cleaning and adding grounds, the switch, etc. I'll get there. Voltage drop in teh cab is now down under 0.5v, from over 1v Anecdotally it seems to push a little more air. It's pulling 3.76 more amps so that's gotta be doing something. Still wish it did more, mainly for defrost. I may pull the blower and lube it and maybe check brushes and anything else I can figure. To do list is find the main ground and distribution spot in the cab and beef that up. I'll likely do either 8ga or 10ga straight from the battery as that's what I have handy and seems reasonable. 4ga would be way overkill.
Also found another thread on adding a blower relay. This guy did more or less the same thing, just not quite as neat an install IMO. BLOWER MOTOR RELAY MOD
"Heater box full of leaves" No, it's clean.
"Crown Vic blower blows much better." No, new CV blower (with fan); works just as poorly as the old stock motor.
"New blower, old one is wore out" No, the CV blower was new.
"Voltage drop between switch to motor" No, jumpered the new CV blower straight to battery; including ground. No switches, nada. Blowed just as poorly as ever.
Conclusion: 7th gen Fords have crappy heaters.
Don't lose any sleep about being banned @ OB. Belonging to a clique is for teenagers.
Yeah the admins over at OB seem to have thin skin. My take is it's a few cops who want to be internet bullies too. Whatever, I've requested all my posts be deleted as I've contributed a lot over there so far as documentation, measurements, etc. in projects that I didn't have to do but took the extra time for the benefit of the community. Screw 'em, I don't want my efforts to be associated with that group.
I looked into this in a similar fashion a few years ago, and tested out the relay deal. For my setup, it blew significantly more air than it does now on all settings, especially HI. That said, something about the Ford design stinks. Dunno what though...
(I never got around to finishing and actually installing the relays, just tested the motor to direct battery mostly, and also ammeter tests)
One other thing that helps a lot is to just barely crack the windows when defrosting. It just lets all that air back out of the cab and gains a little velocity from the vents.
For me it helps about 30% better/faster.
