1986 Ford E150 Van PLEASE HELP
Old Oct 16, 2004 | 12:10 PM
Timdsim's Avatar
Timdsim
I have an '86 Ford E150 van with 5.0 liter engine. I've been fighting a problem with it since I got it. I've replaced fuel tank, both fuel pumps, fuel filter twice, plugs, plug wires, distributor cap, rotor, Fuel Throttle position sensor, and air filter. I had the engine codes checked, and it showed that it was lean on fuel. Rechecked both fuel pumps, and discovered that connector on top of the fuel tank was broken and not making good contact. Fixed that, and it run some better for a while. It would still cut out just before shifting gears a little and at highway speeds some. It has gradually gotten worse and worse, until now my top speeds are 45 to 50 mph. You can just barely push the gas pedal without it cutting out on you. In Park or Neutral, it revs up fine, but in gear, with foot on the brake pedal, it will spit and sputter and backfire.
Please HELP!
Old Oct 16, 2004 | 12:17 PM
pfogle's Avatar
pfogle
That sounds like the ignition control module, it's on the bottom of the distributor, take it off and have it tested (repeatedly if it passes teh first time.) It may be an intermittent connection inside of it.. I would also pull the oxygen sensor and see if it's all carboned up.
Old Oct 16, 2004 | 03:14 PM
Timdsim's Avatar
Timdsim
I already tried replacing the oxygen sensor, and it didn't make any difference. Sorry, forgot to mention that. This thing has been driving me crazy! Any other ideas before pulling the distributor? And which side do I pull it from?
Old Oct 16, 2004 | 09:00 PM
pfogle's Avatar
pfogle
The ICM should be connected to a flat spot on the bottom of the dizzy, it's held on by 2 little torx bolts.... I'm assuming it's EFI and has the TFI ignition.
Old Oct 16, 2004 | 10:00 PM
Timdsim's Avatar
Timdsim
Do I need to pull the distributor?
Old Oct 17, 2004 | 12:57 AM
pfogle's Avatar
pfogle
Yes, unforuntately..... It's not a bad job though
zuczis
Feb 11, 2017 01:59 PM
annaleigh
15
Jun 26, 2016 10:36 PM
F350AK
170
Feb 20, 2016 02:39 PM
Solomon_Man
Nov 19, 2013 11:35 AM
Thomasam
25
May 10, 2012 06:18 PM
