need to know differnces between 7.5 EFI heads
Old Oct 15, 2004 | 03:29 PM
lisagoud's Avatar
lisagoud
Question need to know differnces between 7.5 EFI heads
Gang,
I have a 1989 F250 460 EFI that let go on me destoying the original E7TE heads. I need to know what differences there are between the E6TE series (which I have located a set of as a possible replacement) and the E7TE series which came on my original motor?
Old Oct 19, 2004 | 03:45 PM
leadmic's Avatar
leadmic
The heads you want are E3TEs. They are for 93 and newer 460s. They have a bigger intake valves, larger ports, and a slightly smaller combustion chamber. They flow alot better and will give you just a little more compression. They will bolt on, and every thing will bolt on to them. It should make a diffrence power wise and still work with a stock ECM.
Leadmic
Old Oct 19, 2004 | 03:57 PM
lisagoud's Avatar
lisagoud
Thumbs up
Thank-you...I shopuld have mentioned that this is a fuel injected 1989 7.5...Does that make any difference in your reply?
Old Oct 19, 2004 | 04:02 PM
lisagoud's Avatar
lisagoud
Smile
Lastly, I assume you mean F3TE due to 1993 usage?
Old Oct 19, 2004 | 04:24 PM
scottie2hottie's Avatar
scottie2hottie
If you plan to stay EFI, you'll have to run EFI heads, as they have different shaped intake openings and I believe a different intake angle on them. I don't think year makes a difference as far as them working correctly, but the '93 and newer heads are most desirable. Again, just make sure they're EFI heads!
Scott
Old Oct 19, 2004 | 04:52 PM
leadmic's Avatar
leadmic
The F3TE are EFI heads and are interchangable with E7TE heads. And they are F3s not E3s sorry my bad.
Leadmic
Old Oct 19, 2004 | 05:26 PM
lisagoud's Avatar
lisagoud
Smile
Thanks everyone for your replies. I cancelled my order for a set of replacement E7TE's and ordered a rebuilt set of F3TE's. Is there Anything else I should be aware of during this swap?
Old Oct 19, 2004 | 05:42 PM
scottie2hottie
Don't use the old head bolts(these probably won't come with your new heads)I would definitely invest in a nice new set....Otherwise, dig in and good luck!
Scott
cortina219
Aug 21, 2013 08:17 PM
460plowtruck
May 22, 2013 12:20 AM
lisagoud
Oct 15, 2004 04:24 PM
scoutpup99
Jun 2, 2004 02:26 AM
