lost power through c6
Old Oct 15, 2004 | 02:15 PM
tastyklair's Avatar
tastyklair
i've read numerous places that the C6 will rob about 25% of the engines power. Is this correct? If so then (according to this reasoning) if I'm making 300 rear wheel hp and switched to a manual box I would be at 400hp. This seems like alot.
Old Oct 15, 2004 | 05:52 PM
jfinlen's Avatar
jfinlen
They can suck up to 60 HP at the wheels. A manual may only suck 30. Your choice, but you can fix the c-6 to not suck as much. Call a reputable aftermarket tranny place, they can hook you up.
Old Oct 15, 2004 | 08:42 PM
garypettengill's Avatar
garypettengill
A friend of mine who used to drag race told me that a Ford C-6 requires 58 hp just to run the front pump. That is because the transmission is near bullet proof.
Old Oct 15, 2004 | 09:05 PM
gregm's Avatar
gregm
You can get kits,or some of the aftermarket companies can install the main shaft and planetaries on Torrington roller bearings,or roller washers. this will free up so much horsepower and lower friction inside the case that you won't believe it. Another step that goes along with this is machining the case to accept the bearings.
Old Oct 18, 2004 | 12:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check with Ford Motorsports for the conversion kits: #M-7398-F
Supposedly no case machining is required.
Old Oct 18, 2004 | 04:12 PM
tastyklair's Avatar
tastyklair
How do I get to Ford Motorsports? I found them once before but I can't locate them noe.
Old Oct 18, 2004 | 04:52 PM
beeboy's Avatar
beeboy
You can google that part number and find them.
Old Oct 18, 2004 | 05:36 PM
gregm's Avatar
gregm
Go to www.fordracing.com. This should help.
wills79
Nov 8, 2011 04:59 PM
bartuitschaijk
Nov 4, 2009 01:03 AM
scotv
Feb 25, 2008 11:55 AM
weldingfreak
Iowa Chapter
May 13, 2006 08:50 AM
GeneStoner
Oct 8, 2002 11:13 PM
