dual master cylinder upgrade??
I bought a power brakes kit in 1997 from one of the classic truck magazine vendors. I vaguely recall it costed somewhere around $400, but can't remember which vender I bought it from. It's mounted under the cab in the stock location and is a big improvement over the old stock system. The master cylinder and booster look alot like the setup in my old Mustang. I probably could have saved some money just putting the parts together myself instead of springing for the kit.
Here are some things to think about:
Mounting it under the cab makes it easy to use the stock pedal set up, but it also makes it tough to get at, check levels, etc. We couldn't find a way to locate it and use the stock hole in the floor. The master cylinder ended up right underneath a part of the floor panel that is structural, so I decided against cutting an access hole into it. The end result is I have to check brake fluid levels with a mirror and fill it with a squeeze bottle and tube. Pain in the....
I've seen some guys locate the booster/cylinder in the engine bay like modern vehicles. I imagine they had to ditch the stock pedal and come up with something mounted to the firewall.
Hope this helps.
ROB
Hope this helps.
ROB
Resurrected 56 F100
08-23-2015 07:49 AM
56 ford custom
15
05-31-2012 11:13 PM
kustomchief
06-28-2006 04:21 AM
JefflovesF250s
09-02-2004 09:22 PM
