recommend cam for 351w
Old Oct 14, 2004 | 08:29 PM
stangjay's Avatar
stangjay
I am building a 351w for a 86 bronco. i was wondering if i could get some opinions on cams from you guys. I'm gonna run a rebuilt block bored .030, forged pistons, non-roller cam, windsor jr. aluminium heads,edlebrock performer rpm air gap intake, holley 700 double pumper carb, 2000 rpm stall,c6 trans. I don't care too much about drivablility as this is not my daily driver. I just want the max performance. I plan on using it for beach driving, sand drags, and occasionl towing. Any help is much appreciated. thanks
Old Oct 15, 2004 | 02:06 AM
mako5972's Avatar
mako5972
Take a look at the Comp Cams Xtreme 4x4 cam line. The cams have lots of grunt. I would also look at a Holley Truck Avenger carb instead of the double pumper. Try www.compcams.com page 84 of the catalog or call 1 800 999 0853.
Old Oct 15, 2004 | 07:02 AM
jwtaylor's Avatar
jwtaylor
If your after the most power out of your combo, then you'll be wanting a custom cam. search for cam motion
or you can do a search on corral.net search for FTI and buddy rawls
In some cases they don't cost a whole lot more than an off the shelf cam, comp could do a custom cam as well.
Old Oct 16, 2004 | 12:45 AM
Netfly's Avatar
Netfly
check Edelbrock for Performer RPM cam:
http://www.edelbrock.com/automotive/cams_ford2.html#rpm
It matches thier intake, best way to go.
Have an 85 Bronco 351w, used the performer intake & cam, custom rebuilt .030 over motor. Nice results.
Old Oct 16, 2004 | 01:52 AM
ford390gashog's Avatar
ford390gashog
try a crane
OGLIGHTNING
Jun 11, 2016 11:53 PM
bountyhunter1650
Apr 7, 2016 06:59 PM
FORDFTW
Apr 23, 2009 11:52 PM
Ken Blythen
Apr 1, 2008 04:34 PM
wedefyu
Mar 4, 2008 04:44 AM
