351w HO cylinder heads or efi cylinder heads
So here's the scenario I have an 87 ford f-150 with the 351w HO motor. The motor is no good and I picked up a 92 351w with EFI to replace it. I am staying carbureted.
So my question is this which cylinder heads will flow better the HO or efi?? I am going with an edelbrock peformer rpm cam and inake. Eventually I will get the performer rpm cylinder heads but for now was wondering which ones out of the HO and efi would yield better performance gains?
I had a link at one time with cylinder head flow numbers but can't seem to find it.
Any help it very much appreciated.
on
The only spec I have for D7OE is for 302 heads, if that's what they are they will have 1.78/1.45 valves and 69cc combustion chambers.
But if the heads have 1.84/1.54 valves they are 351 heads with 60cc combustion chambers.
Are there any casting marks on the top side around the rockers identifying them as 302 or 351? If not you need to measure the valves.
As best I can measure in with a tape measure and flash light I giot 1 7/16" on the small valves and 1 13/16" on the big valves
Now that I measure the smaller valves a little more carefully they're just under 7/16 mark about halfway to the next smaller mark I need a micrometer or something to get a more accurate measurement
Well 1-7/16" is 1.438", so most likely those are 1.45" exhaust valves.
1-13/16" is 1.81", which is right in between the 1.78" and 1.84" intake valve sizes. However 1.78" is the size that should be found paired with the 1.45" exhaust valve, and if so, they will measure a smidge under 1-13/16".
I think some of the later "good" production heads still use the small valves. And also for some years in the '70s 302 and 351W heads were the same piece except for head bolt hole size.
Are you sure that the "5" on the head is not an "S"? That would be in keeping with the T and R markings.
The E7TE head will be much better than the D7OE units. Hopefully the other head is a match for this head.
mfewtrail
12-10-2016 03:38 PM
rkcarguy
08-08-2013 12:00 AM
tonylo
03-10-2012 09:13 PM
corner27
09-22-2010 10:27 PM
351, 351w, 94, cylinder, e5, e7, efi, ford, head, heads, identification, measurements, performance, specs, truck
