98 ranger issues pls hlp
Old Jan 1, 2003 | 09:16 PM
nillig's Avatar
nillig
I ran in to a potential problem while fixing my temp cantrol. i had to unhook the passanger airbag on an off switch to remove the panel. with one problrm fixed i created another one. now the airbag comes up with a fault code loks like 27. everything is connected. is there something that i have to reset or could it be a major problem. i did start the truck with the connection unhooked. any help would be greatly appricated
Old Jan 2, 2003 | 12:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
You will have to unhook the battery or use the method spec'd in your repair manual to clear the codes. Supposedly they will clear themselves after a while...
Also, never mess with the air bags. They are small bombs that can maim or kill you if they go off at the wrong time.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 2, 2003 | 07:27 AM
nillig's Avatar
nillig
thanks i'll try that
marc
Old Jan 2, 2003 | 06:43 PM
Ken00's Avatar
Ken00
If I remember right thats the passengers side warning light not wotking, try doing a search I know I have replied about this code before. If you don't find anything and still have the problem bump this post back to the top and I'll look it up in my manual. I do not recommend wotking on air bag systems without all the proper precautions.
Old Jan 3, 2003 | 06:54 AM
nillig's Avatar
nillig
That may be it. Because the only thing I did was unhook the connector from the passanger side on/off switch. Could the switch have gone bad? Or could it just be that the fault light needs to be reset or something like that. Looks like I may be making a trip to the dealer monday if I can't figure it out before hand.
Thanks
Marc
Old Jan 3, 2003 | 10:10 AM
Ken00's Avatar
Ken00
Try unhooking the battery like Torque1st said, if that doesn't work I would recommend a shop or a VERY good manual.
Old Jan 3, 2003 | 05:52 PM
nillig's Avatar
nillig
tried the battery, left it unhooked for 10 min. still didn't work. i think it may be the passanger airbag light. well thanks for all the help, looks like its off to the shop on monday,
marc
Old Jan 3, 2003 | 09:26 PM
garymake's Avatar
garymake
In the past, when I had tried to reset the computer by disconnecting the positive cable, it has not always worked....
Talking to those who were better informed than I, I was told that the best way to assure that the computer is reset is to disconnect the positive cable from the battery and place it on the negative terminal for 1-2 minutes. This discarges all potential in the system and resets the computer.
It made sense to me and this is how I have reset the computer on various vehicles ever sense (this has always worked for me).
You might want to give that a try just to make sure before going to the dealership...
Gary M.
White 2002 F250 SD, SC, SB, 4x4, 6.8L v10, 3.73LS, 4spd Auto, Reverse Aid Sensor, Class IV Hitch, Offroad Package, Manual Hubs, 40/20/40 Bench Seat, Towing Package, Camper Package, Lariat, Putco Locker Side Rails, Mud Flaps, K&N Filter, Vent Visors, Aluminum in-bed Tool Box (sits in the bed, dosn't hang over the bed rails), Vent Visors, CB radio w/102" SS Whip Antenna, Autolocks programmed off, Seatbelt Minder programmed off, Key in ignition sensor wire dosconnected...
White 2002 Ranger 4x2 3.0L V6 XLT 2 door supercab with the power group, auto, chrome wheels, mud flaps, body side molding, vent visors, Leonard cab high fiberglass camper shell, and the 60/40 bench seat as my daily driver
Old Jan 4, 2003 | 05:37 PM
DTorix's Avatar
DTorix
I had a similar code one time. I had started the pickup, forgetting I needed to turn the airbag back on. Killed it quick, turned on switch with key, and restarted. Got error 24 or 27, don't remember right now.
To fix it I turned the airbag switch off. Turn on ignition and allow all the self test to cycle. Turn off ignition. Turn on airbag. Turn on ignition, allow to cycle. That fixed it. I'd try that before spending any money.
Dave T.
Old Jan 7, 2003 | 02:27 PM
nillig's Avatar
nillig
finally went to the dealer.....luckly it was covered under that extended warrenty that i had forgotten i had purchased...good thing too. it was the switch for the passanger side airbag it had gone bad and needed to be replaced. i would like to thank everyone for all their help.
ps. the whole system was deactivated while the fault was still present.
thanks guys
marc
Old Jan 7, 2003 | 05:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks for posting the solution
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
Old Jan 8, 2003 | 08:24 AM
katdaddy's Avatar
katdaddy
You'll find that the light bulb has burned out on the passenger side switch (where the key goes). I just had the same problem. If you take the switch apart you will see a small circuit board with a tiny bulb soldered into it. I went to Radio Shack and got a tiny 12-volt bulb and soldered it on. No problem since.
Good luck!
Old Jan 8, 2003 | 01:17 PM
Ken00's Avatar
Ken00
bronkntrukholik
Jun 2, 2016 08:25 PM
ksidlosky
Feb 17, 2013 09:21 PM
brc777
1997 - 2003 F150
Oct 16, 2009 04:41 PM
brc777
1997 - 2003 F150
Oct 15, 2009 09:46 PM
cecoen
Electrical Systems/Wiring
Sep 16, 2006 09:38 PM
