Check engine light
Old Oct 14, 2004 | 04:12 PM
johneent's Avatar
johneent
Check engine light
Hi guys. I need some help in sunny Barbados. I have a 1997 Eplorer Ltd 4.0 SOHC.This evening the check engine light came on. What is the most likely cause for this? John.
Old Oct 14, 2004 | 05:32 PM
1081's Avatar
1081
One of about 30 or 40 things! You should run by your nearest Auto Zone if its available and have them read the code, it is free. Once you get the code you will begin to narrow it down. Also spend some time on this web site because there are numerous threads dealing with the codes. The search function is down right now so you kind of have to knock around some.
Old Oct 14, 2004 | 07:40 PM
johneent's Avatar
johneent
Thanks
Thank you. Unfortunately there is no Autozone in Barbados and certainly no free service.I will have the codes checked asap. John.
Old Oct 14, 2004 | 09:08 PM
1081's Avatar
1081
I kind of figured that. You might spend some time at fordfuelinjection.com it has pretty good information and may even tell how you can read the codes (I think). It is fall here and I can only guess it is warm there.
CommuterAir
Nov 13, 2024 07:53 PM
smileyp
Escape & Escape Hybrid
Nov 5, 2016 11:44 AM
Lima0331
Apr 20, 2016 05:59 AM
rachase70
1997 - 2003 F150
13
Aug 31, 2007 09:12 AM
Avanti
Apr 13, 2001 02:37 AM
