Fuel milage
Old Oct 13, 2004 | 06:31 PM
Bt Doctur's Avatar
Bt Doctur
Fuel milage
A newbie here to the room,main issue is fuel milage on front tank 19 G 260 ish to empty (motor dies) v.s rear tank 18 (150ish) to motor dies.Began to show up at around 170000 miles.A 1995 F-250 ,351 EFI 4x4 .4spd auto.Fuel pressures have not been checked yet, performance good on either tank,no cross feeding between tanks, caps and emissions prefect,240000 current.So far no one has an answer.
Old Oct 13, 2004 | 07:32 PM
Popa Tim's Avatar
Popa Tim
Asside from fuel pressure issues, perhaps there is more water in the rear tank. Once you think its empty (motor dies) there is always some gas & water left. Try having it drained and see if that helps, but I think you would notice that you are only putting 15 gal back in... just a quick thought if you hadn't checked this yet.
Popa Tim
Old Oct 14, 2004 | 04:40 PM
Bt Doctur's Avatar
Bt Doctur
Sorry, left that part out. When the motor does quit ,the tank that was used refills up to the normal capacity.Ft tank refills to 18.8- 19 G,rear refills 17.8-18 G. There are no leaks at the rear tank area .Tank caps were changed.Miles charted with mile markers and gps. This has been going on for some time now and it has everyone stumped.All fuel systems are OEM at this point in time.never touched or opened.
Old Oct 14, 2004 | 04:47 PM
Frankenstang57's Avatar
Frankenstang57
I thought the rear tank only held about 15 gal. I don't think I've ever put more than that in it.
Old Oct 14, 2004 | 07:51 PM
Frankenstang57
D'oh, my bad. I looked it up and the truck has a 37 gallon fuel capacity, ignore me!
Old Oct 18, 2004 | 05:24 PM
Bt Doctur's Avatar
Bt Doctur
I know it`s a strange trouble but I`d really like to have the same mileage from both tanks.Hard to understand what the trouble can be.
GondolaRides
27
Jun 4, 2013 12:21 PM
dakotarider
Mar 28, 2013 09:46 AM
OneLong4x4
Dec 10, 2012 11:00 PM
a ayala
Nov 2, 2009 08:06 AM
roger 922
Mar 16, 2008 10:30 PM
