Dual tanks q?
Old Dec 10, 2012 | 12:38 PM
OneLong4x4's Avatar
OneLong4x4
Dual tanks q?
1990 F150, 4.9L, 5 sp manual, 4x4
Dual tanks question.
Truck was nearly outta gas the other day. Went to station and filled up the rear tank. Went to fill front tank and nasty yellow-ish fuel came out right away. So it was full - and has likely been for several months.
When the fuel switch is placed in R position, everything good. When switching to F, truck immediately sputters and dies.
So my problem is fuel pump in the front tank, right? Anything else it could be based on my description?
Thanks -
C.J.
Old Dec 10, 2012 | 02:11 PM
Conanski's Avatar
Conanski
Yes your front pump is dead and you have the fuel transfer problem which should be fixed when you replace the complete fuel delivery module in that tank.
Old Dec 10, 2012 | 02:28 PM
OneLong4x4's Avatar
OneLong4x4
Thanks for your quick reply! Can you give me a part number of what I am after? I looked on RockAuto but see modules called out for the rear tank, not front. Thanks!
Old Dec 10, 2012 | 11:00 PM
jaagen's Avatar
jaagen
Not sure if you know (but probebly do) but the front tank is called midship tank.
Gstan
Apr 14, 2019 06:20 PM
SouthernBlues
Feb 2, 2017 05:39 PM
jtm8571
Jul 28, 2009 12:00 AM
Redleg319
Mar 17, 2004 08:52 AM
Dogman4324
May 6, 2003 11:15 PM
