Salutations FTE Citizens
My plans are to increase tire size, ride height or both. I have a pretty high gear which revs my engine more than I would like at highway speeds. I replaced the entire a/c sytem and it blows cold with R132. I just replace the deteriorating exhaust with duals from the stock manifolds run through mellow-tone mufflers. It is smog delete and runs much better with a deep big-block tone. I have some fuel gauge issues to work out, which I am finding is not uncommon. The egr was stuck with broken vacuum lines everywhere. I cleaned the egr valve and replaced the vacuum lines with bulk material. I no longer get codes...the computer is happy and I'm up to 9 MPG from 6 MPG.
Anyway, thanks go out to everyone who posts great questions and the variety of opinions and facts posted as replies. Opinions are often a source of out of the box thinking that can connect the right dots to find a solution. They are also a source for entertainment which is a welcome diversion from what might otherwise be a dry Q&A session.
My hope is that I will be able to add insights that in some small way will help others as they have helped me.
Thank you FTE for providing this venue and to the members for their $0.02 worth.
