ticking 5.8
Old Oct 13, 2004 | 04:18 PM
reoots's Avatar
reoots
ticking 5.8
I have a ticking sound i can't locate. It goes away when put in gear. it is not a valve or lifter. It also goes away if i pull both the #5 and #6 plug wires. it is a little deeper sounding than a rocker. anyone have any experience with this?
thanks for any help
Old Oct 14, 2004 | 12:38 PM
Powers6869's Avatar
Powers6869
Check the pipe leading from the EGR valve to exhaust manifold. It is probably cracked and separated under the sock around it. Had same problem, replacing pipe will fix it.
Old Oct 17, 2004 | 08:40 AM
reoots's Avatar
reoots
thanks
thanks for your advice, it was broken. i got a new one from ford and installed
it. unfortunatly the noise is still there. I'm thinking it may be a wrist pin.
strat875
Modular V8 (4.6L, 5.4L)
Oct 15, 2016 02:35 PM
TooHuge
2004 - 2008 F150
Feb 1, 2016 01:32 AM
berry1234
2009 - 2014 F150
Dec 31, 2015 01:37 PM
2010F350
6.4L Power Stroke Diesel
Nov 13, 2015 11:52 AM
moore89
Jun 22, 2003 07:40 PM
