89 ford ranger hub question
Old Dec 6, 2002 | 05:14 PM
TOUGHLover's Avatar
TOUGHLover
Old Dec 18, 2002 | 07:36 AM
mittins's Avatar
mittins
Ok here you go, ever time I try to engange the 4x4 button on my "push button" 4x4 it justs banges and grinds "badly". I want to put manual hubs on it. But before I do that I want to know what is the required torque to seat the bearings before you put the cap on??? I know my Hubs didnt burn out!!! there just not engaging!
Old Dec 18, 2002 | 01:50 PM
mathelm's Avatar
mathelm
According to the haynes manual, 35ft/lbs, back off 1/4 turn, then 16ft/lbs on inside nut. And 150ft/lbs on the outside one. This is all from memory so somebody double check me.
Old Jan 15, 2003 | 06:54 PM
dracko_26's Avatar
dracko_26
I had the same problem on my 93 ford. I found out that the bearings in front were badly used, but no scaring. I changed the bearings, and everything was ok.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
