Water problem
Old Oct 12, 2004 | 07:26 PM
Steve91's Avatar
Steve91
Water problem
2004 FX4 SCAB, two weeks off the lot, built in August...
My right front carpet gets wet after it rains. I can also hear water sloshing around somewhere on the right when I am stopping.
Anybody else?
Old Oct 12, 2004 | 08:15 PM
Ulf's Avatar
Ulf
I also had a problem with the right front carpet getting soaked when raining, no water sloshing though.
It turned out the dealer found a wire harnes gromet not installed all the way in the fire wall, it was alowing water to enter through the opening. All OK now.
Old Oct 12, 2004 | 10:57 PM
kittyhawk's Avatar
kittyhawk
The sloshing is water in the floor channel that runs next to the doors there is a rubber gromet down there that some times is not installed the correct way from the factory.
Hope this helps.
Dave
Old Oct 23, 2004 | 03:37 PM
polaris4x4ex's Avatar
polaris4x4ex
water leak
hello i have 2004 screw, i had the same problem and they found the leak between the hood cowl and the fire wall,they forgot to seal it. thats fixed now.
Old Oct 23, 2004 | 06:30 PM
bigwtx's Avatar
bigwtx
Count me in on the right front leak too. I took it in, but they said something about the water channel from the rear window to the front... They fixed the problem but I'm not sure what the cause was.
Old Oct 24, 2004 | 06:56 PM
Steve91's Avatar
Steve91
I have an appointment for Tuesday. I hope they fix it on the first try!
tankblake
2004 - 2008 F150
18
Sep 22, 2018 04:59 PM
00GT
1997 - 2003 F150
Oct 8, 2011 09:58 PM
64Shortie
Aug 29, 2006 01:20 PM
mikeyswood
Apr 5, 2006 08:52 AM
ford23
Apr 29, 2003 07:08 PM
