first start up psd smokes blue
Old Oct 12, 2004 | 05:43 PM
crapr6's Avatar
crapr6
hey guys i have a 94.5 f350 PSD. The intire summer was ok when first start ups (just smoked alittle), but now its getting to about 40ish out in the morning and the truck will smoke blue for about 5 mins when first started, and seems to run alittle rough also. I alow the glow plugs to warm up the cylinders before starting the truck but it smokes still..could it be some bad glow plugs,injectors???please help guys before winter hits and i get really cold here in New Jeresy.
p.s. all fluids are NEW all filters are NEW, the only other thing is that i just filled up at some no name brand gas staiton (cheapist place around for fuel)
thanks guys
erik
Old Oct 12, 2004 | 11:06 PM
ltfox's Avatar
ltfox
I belive that a little smoke on startup is normal. But its a good idea to check out the glow plugs. Mine smokes a little blue and rouns rough like your talking but not till it gets around frezzing.
Old Oct 13, 2004 | 07:45 PM
freddyfast9's Avatar
freddyfast9
I have had some blue smoke too even when it's warm and still can't locate the problem.
Old Oct 13, 2004 | 07:57 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A little smoke on a cold start is not unusual. It's the nature of the beast. You may have a bad glow plug or two, or a weak relay. Your rings may be worn too if you're high milage, not much of an issue as long as it's running right.
Freddy. You might have nicked an o-ring when your injectors went in.
Old Oct 14, 2004 | 01:51 AM
freddyfast9
I will check the O-rings and glow plugs,the bad thing is that the only codes that it was throwing were ICP and a timing code which I attribute to the turbo,chip and injectors.thanks for the advice
Old Oct 14, 2004 | 08:20 PM
crapr6's Avatar
crapr6
hey guys thanks for the reply. NO it smokes heavlly blue for like 5 mins in the morning when i let it warm up, then when i drive away it leaves a smoke trail behind me for about 1 or 2 miles. it also runs really rough like a miss fire. Like i said this happened once it starter to get colder around here in New Jeresy. I ordered glow plugs at a local ford dealer yesterday just for the hell of it, plus they are only $10.00 a peice (OE ford parts). I dont know of the service history of the truck ( i just bought it 5-6weeks ago), but i have when through the intire truck "fluids,filters,etc changed". I dont know if the truck has had the glow plugs replaced, but it has 154,000 miles on her. Thanks guys.
erik
p.s. it kinda started acting up after i fueled up at some no name brand gas station (cheapes fuel price around). i dont no if its bad fuel of what, but i have a new fuel filter in her.
Old Oct 15, 2004 | 01:44 PM
crapr6's Avatar
crapr6
well today i picked up 8 glow plugs and the glow plug relay, i was going to replace it today, but it just started to rain. iam going to wait and see when its going to stop rain then ill install the parts. ill let u guys know how i made out. thanks again
erik
Old Oct 15, 2004 | 04:34 PM
FORD352V8's Avatar
FORD352V8
Hmmmmmm, that much smoke has me worried. How much miles you have on the motor? It may be rings or valve guides. I had an old dodge 318 one time that would do the oppisite, it was fine til it was warm and then started smoking terribly.
Old Oct 15, 2004 | 05:17 PM
crapr6's Avatar
crapr6
i dont think its internal problems, iam sure of that. this just started to happen once it started to get cold out here. the motor has 154,000 miles on it.. ill let u know what happens after this weekend, iam going to replace the glow plugs, and glow plug relay. thanks
erik
Old Oct 15, 2004 | 07:20 PM
94.5turbodiesel's Avatar
94.5turbodiesel
I have a 94.5 too with 185,000 on it. I too have to exact same symptoms as your truck. Let us know how you fix it.
Old Oct 17, 2004 | 01:38 AM
Chaps's Avatar
Chaps
Was having the same problem on my 94.5 w/150k. Injector o-rings (external & internal) fixed it.
Old Oct 17, 2004 | 11:16 AM
crapr6's Avatar
crapr6
well iam going outside in about 1 hour to replace the glow plugs,but can u explain more about the injector o-rings(external and internal)? what must u do to replace the o-rings?remove injectors?what do u mean by internal and external o-rings? what is weird with my truck is it just started to do once it got cold here...but i dont understand the BLUE smoke??isnt that oil burning??not fuel (raw fuel i though is black). thanks for ur reply,
erik
Old Oct 17, 2004 | 12:47 PM
Chaps's Avatar
Chaps
What I think is going on: The injectors have o-rings separating the fuel chamber from the high pressure oil chamber. When those o-rings get old they get hard, especially in a cold engine. When you start up from cold some of the hi pres oil is forced past the old stiff o-rings causing the blue smoke. When the engine gets a little warmer the rings soften and begin to seal properly. Don't just replace the outer o-rings, the injectors should be removed and gone through by an injector shop - totally solved my problem.
BTW, the early PSD's had particularly bad 0-rings
Old Oct 17, 2004 | 03:23 PM
freddyfast9
chaps that makes sense and cookie I will check those O-rings soon I just have not been in the mood to tear into it right now getting tired of wrenching lol.
Old Oct 17, 2004 | 04:37 PM
crapr6's Avatar
crapr6
well i just got in from changing the glow plugs. First i did the passenger side (no problems), then i went to the driver side. after removing the valve cover i seen the front harness connection (valve cover gasket to inj& glow plug) was melted BAD..i pulled the connector apart and found that the end wire (first cylinder on driverside glow plug wire) is smoked (melted). i sat for about 30mins and was think away to fix (because this is my primery vechile, mustang not street legale) well i just jump the melted wire and spliced in a new wire..its a rig job till i can order a new valve cover gasket and inside harness from ford tommorow....i installed the new glow plugs on the driverside and finshed up. I turned the key to on and tested the power to the harness...test light is on..its a go...started it, drove around a few miles. Now i must wait till tommorow moring to see how it starts COLD..if it still smokes blue then i will replace the injector o-rings MAYBE even get some HI-preformance injectors if i have the money..thanks again for the reply and great info.
erik
