carb choices for a 360?
Old Oct 12, 2004 | 03:47 PM
nomeansyes's Avatar
nomeansyes
Question carb choices for a 360?
I just purchased a '74 F100 with 55K actual miles. It's completely stock and has a 360ci engine with a 3-spd manual trans and gets about 12.5 mpg. Is there a more fuel efficient carburetor I can use in place of the stock set-up? Any feedback would be greatly appreciated.
Old Oct 12, 2004 | 03:55 PM
rusty70f100's Avatar
rusty70f100
Welcome to FTE!
Here's what I would do:
1. A set of headers, the manifolds suck.
2. A 4 barrel intake
3. A holley 600cfm vacuum secondary
4. Keep your foot out of it!
This setup will get you more mileage IF you can obey step #4.
Old Oct 12, 2004 | 04:29 PM
Annihilator's Avatar
Annihilator
Right on Rusty!
Old Oct 12, 2004 | 08:33 PM
nomeansyes's Avatar
nomeansyes
Thanks for the reply. I'll consider your suggestion, sounds like $$ for all that stuff. Will start shopping around. Any intake or headers better than others?
nomeansyes
Old Oct 12, 2004 | 10:51 PM
fordbeast_80's Avatar
fordbeast_80
edelbrock RPM, headmen.
Old Oct 13, 2004 | 08:58 AM
rusty70f100
Yep, hedman makes a good set of headers. Just get the Victor Nitroseal gaskets and they wont leak. I would also advise a set of the soft aluminum collector gaskets; I've had bad luck with the regular ones.
Old Oct 13, 2004 | 09:02 PM
fordbeast_80
or if you just want a carb, jegs' summit has a 500 CFM, two bbl.
Old Oct 22, 2004 | 01:48 AM
jar's Avatar
jar
I've got a '74 f100 with the Holley 500cfm 2bbl carb from summit. It showed a very small increase in mpg. It definitely runs smoother.
Old Oct 24, 2004 | 12:04 AM
nomeansyes's Avatar
nomeansyes
This is all good information... I've been looking around at headers, intakes and carbs; just need to finish the other project before I start another! Besides, the truck runs fine for the short term but, at $2.38/gallon here in So. Cal., I may need to do something sooner than later.
