1989 f150 code 35
Old Oct 12, 2004 | 02:09 PM
FordOwns's Avatar
FordOwns
1989 f150 code 35
Hello, I have an 89 f-150, 302, 5 spd truck, and it's getting bad gas mileage, and sounds like the lifters are tapping. But they only tap in 5th gear, about 3/4 of the way up a good sized hill we have here in Texas.
I took it to AutoZone, and they ran a diagnostics on it, with the key off, and the truck threw code 35 as the only code. Should I get them to run a test with the engine on, and what does fixing a code 35 entail? I'm a carbd mustang fan, but I don't know jack about the fuelie 302s.
Thanks in advance!
Old Oct 12, 2004 | 04:45 PM
F150xlt's Avatar
F150xlt
If this is a Code they retrieved from memory, Code 35 is a EGR Valve Position Sensor problem.
The EVP sensor monitors the movement of the EGR diaphram. It's mounted on the EGR valve and has a 3 wire connector.
When the EGR valve opens or closes, the diaphram moves.
The sensor monitors the movement and sends a voltage
back to the computer. If the voltage isn't what the computer thinks it should be, it sets code 35.
Could be a wiring problem, EVP sensor or EGR valve.
The manual says to attach a hand held vacuum pump and monitor the EVP voltage as you open and close the EGR valve.
Old Oct 13, 2004 | 10:15 AM
mike L's Avatar
mike L
Vacuum hose??
Pull the vacuum hose off the EVP silinoid and see if theres suction. Do you have carbon on spark plugs, or place a white rag over the tailpipe and see if it turns black.
Old Oct 13, 2004 | 01:41 PM
FordOwns's Avatar
FordOwns
Thanks for the replies! I'll go see if I can figure out which one of the named culprits it is. On fox bodys, the egr is behind the carb, on a plate that the carb sets on. Where would it be on this truck? Thanks guys for helping me out!
Old Oct 13, 2004 | 02:56 PM
guzzler96's Avatar
guzzler96
Post
On my '90 its just behind the throttle body on the passenger side. You should see a tube coming out from under the Upper Intake Manifold that will come to the bottom of the EGR valve. The VPS(Valve Position Sensor) on mine sits right on top of the EGR w/ an electrical connection going to it.
jwdenney2
2004 - 2008 F150
Dec 23, 2015 01:15 AM
standardtransonly
Oil & Lubrication
Sep 8, 2014 05:08 PM
jeffreyt
25
Jul 22, 2014 10:02 PM
Will5o5
Apr 26, 2014 04:14 PM
