Aerostar Ford Aerostar
High And Low ac PSI
Old Oct 15, 2004 | 10:15 PM
copper_90680's Avatar
copper_90680
Hi Frank:
That's exactly what I did too, but it was kind of messy and my wife didn't want me to use her cooking pots for that purpose. I'm assuming that CBR900 is as terrified of his wife as I'm of mine
Old Oct 16, 2004 | 05:47 PM
cbr900's Avatar
cbr900
hey thanks guys, no I am not terrified of my wife I wear the pants in this house, when my wife has finished with them that is. One other problem my can of freon is a 30lb jug so how am I going to heat that up, and is it safe to do so?.
Old Oct 16, 2004 | 07:56 PM
copper_90680
Where do you get a 30lb jug of R-134? Isn't it kind of an overkill? Anyway, I used a standard 12oz can you buy at the autoparts stores and those things get cold very quickly, thus reducing the pressure. However, with a 30lb jug, I don't think you would have that problem. Just run the A/C and rev up the engine, that ought to do it. The A/C has to be running, however. You may have to pull the connector at the receiver and jump a wire across to keep the A/C running.
Old Oct 17, 2004 | 06:05 AM
Frank Kistner Sr.'s Avatar
Frank Kistner Sr.
A method I used for years when adding freon to a low system was feeling the lines going into the evaporator, both should feel about the same temperature, also the lines should get very cold and produce a sweat. So, when the lines are cold and produce a sweat your compressor should cycle normally thus you have enough freon in the system. As I live in Florida and have plenty humidity year round it works for me. However I don’t know if it would produce the same results in the dry regions. Be careful not to over charge.
Frank
Old Oct 17, 2004 | 07:52 AM
cbr900's Avatar
cbr900
I got the 30lb jug from work, one of the a/c mechanics gave me it and some adapters so I could hook it up to the van, and I forgot to take it back.
LibTimothy
Texas Chapter
Apr 11, 2015 12:09 PM
frank7mm
Nov 28, 2012 03:27 PM
gbishop
Jun 19, 2009 03:12 PM
j.frank
Jan 7, 2000 12:52 PM
j.frank
Nov 9, 1999 06:38 AM
