Cab differences between 78-9 and 73-77
Old Oct 11, 2004 | 10:55 PM
madcitymike's Avatar
madcitymike
I have a 78 standard cab that needs replacing. I've heard that the 78-9 cabs are the only ones that can swap. The 73-77 cabs look identical to me, and those are the only ones I've been able to find. What is different about them? Are the mounts in different locations or something?
Old Oct 12, 2004 | 01:55 AM
highboy1975's Avatar
highboy1975
from what i've seen theyre the same as well, im pretty sure the only different ones are on the 73-77 f250s with the narrow frame. plus they have the in cab tank. anything should work that is off a similar truck, what are you putting the cab on?
Old Oct 12, 2004 | 11:34 AM
79_250RangerLariat's Avatar
79_250RangerLariat
all the cabs are the same. keeping body style specific you can pull a cab off a any 73-79 F100-350 2wd/4wd etc and it will fit. You may need to modify the floor pan (if the 4wd bolt on cover isn't there) but other than that they will bolt on
Old Oct 13, 2004 | 06:43 AM
F150daniel's Avatar
F150daniel
78 and up have shoulder belts and the 77 and earlier don't.
Old Oct 13, 2004 | 06:47 AM
divit250r's Avatar
divit250r
I'm not so sure about that, my dad's 76 F100 has shoulder belts.
Old Oct 13, 2004 | 07:55 AM
paulsrx700's Avatar
paulsrx700
cabs
I believe in 75 they started putting the shoulder seat belts in, but for sure they started in 76. The only difference in the mounting bolts is in the rear of the cab. The 73-77 cabs rear mounts are narrower than the 78-79 cabs. If you look underneath, the other holes is there only through one thickness of sheet metal, just drill through. Then on the inside you have to cut a access hole in to put the bolt in, just measure the center distance from the bottom and transfer the hole.
Old Oct 13, 2004 | 06:51 PM
Monster 78 F-150 4X4's Avatar
wiring harnesses so keep your harness from your cab and swap it into your new cab because 73,74 had one harness, 75-77 had another harness, and 78,79 had another one the only other differences are holes for trim like rocker (Ranger XLT) race track and single top style line trim. its easier to put holes in for trim then to take them out
Old Oct 13, 2004 | 09:02 PM
kermit's Avatar
kermit
shoulder belts were an option from '73, but later on they started being the auto retractable stuff and not the same design as the regular lap belt
Old Nov 25, 2004 | 11:14 PM
whd507's Avatar
whd507
75.5-79 are the same, 73-75 will fit but no shoulder belts.
the floor pan issues are asy to fix, just get the flat cover to cover the hole if there is one. if you need the hole, just cut it.
regular frame or narrow, the cabs are the same. if you need teh in-cab tank, get the right cab, filling the filler hole is easier than cutting it...
Blown 331
146
Oct 17, 2014 01:45 AM
brian1080
Apr 28, 2014 06:47 AM
nisvec22
Sep 3, 2012 01:10 PM
bryanmartin
20
May 22, 2012 12:05 PM
BlueOvalBud
Aug 15, 2010 09:56 PM
