f600
Old Apr 25, 2014 | 08:13 PM
brian1080's Avatar
brian1080
f600
a 78/9 f600 has the same cab as the pickups correct, minus the dash? I know the whole front clip is different, but IIRC the cabs were interchangeable.
Old Apr 26, 2014 | 09:25 PM
brian1080's Avatar
brian1080
none of you know, hogwash!! :P
Old Apr 26, 2014 | 10:20 PM
JWC 3's Avatar
JWC 3
Someone has a build thread here using larger truck cabs .... I'll see if I can find it
Old Apr 26, 2014 | 10:27 PM
JWC 3's Avatar
JWC 3
78 F800crewcab4X4 . F600 super bronco build . Try that ... Best of luck !
Old Apr 27, 2014 | 12:18 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes same cab as far as I have seen, but yes way bigger/wider front fenders (cool), doors that have the push button instead of the lift handle (way cool).
And WAY WAY diffident instrument cluster mount design....here you go. And the steering column is not mounted in the slot at the bottom of the dash like a 73-79.
Last pic is a f600 instrument cluster being modded in to a 73-79 reg dash.
Old Apr 27, 2014 | 03:23 AM
rockittsled's Avatar
rockittsled
Now for a dumb question....will the F600 dash have the same mounting points as a F100/250?
Old Apr 27, 2014 | 03:45 AM
Xauterus's Avatar
Xauterus
I think the F600 dash is welded in. But that doesnt make it an impossible conversion.
Old Apr 27, 2014 | 07:25 AM
5851a's Avatar
5851a
Thought there was something about the firewall being the same as the bump sides, could be wrong.
Old Apr 27, 2014 | 09:17 AM
brian1080's Avatar
brian1080
Thanks for the input. Considering a new toy but wanted to know before I jump.
Old Apr 27, 2014 | 09:25 AM
77&79F250's Avatar
77&79F250
Brian what are you looking into?
Old Apr 28, 2014 | 06:47 AM
Justin.Hoeben's Avatar
Justin.Hoeben
In south africa all our 73-79 f100,f250 and f350 trucks comes standard with this dash. Its all RHD though
Ed_78SuperCab
17
Apr 28, 2026 09:59 PM
78_f800crewcab4x4
343
Dec 17, 2022 04:39 PM
xcalbr2
Ford Truck Parts for Sale
Mar 15, 2014 09:28 AM
1978Crew
Aug 20, 2004 10:48 AM
koto
Apr 23, 2001 09:57 AM
