Checking transmission fluid?
Old Oct 11, 2004 | 05:26 PM
mcjones44us's Avatar
mcjones44us
Guys --
After hearing one too many horror stories about Jiffy-Lube and other types of fluid-change folks, I decided to change my own transmission fluid and filter using the procedures outlined on a web site.
Everything went OK with the change, but I'm having an enormous amount of trouble reading the stupid transmission dipstick. I don't see what I'd consider to be a definitive reading on the stick. The oil looks smeared, puddled, etc.
I follow the basic directions in my owner's manual. Drive the truck until the transmission heats up, then park on level ground and allow about 30 minutes for fluid to drain back into the pan.
Can anyone give me any hints/tips/techniques into reading the stupid dipstick properly?
Mike
Old Oct 11, 2004 | 10:31 PM
RickyBR's Avatar
RickyBR
Check the fluid with the transmission at normal operating temperature. Leave the truck idle while you check the fluid.
Old Oct 12, 2004 | 07:47 AM
mueckster's Avatar
mueckster
Try rinsing the dipstick with water and drying with a clean towel. This helps create a uniform clean surface for the fluid to stick to and provides for a more accurate reading.
Old Oct 12, 2004 | 11:29 AM
Jerrybo66's Avatar
Jerrybo66
Originally Posted by mcjones44us
Guys --
Mike
I know exactly what you're talking about. I have the same problem with the oil stick on my Jeep J-10 pickup. I tried everything, cleaning, roughing the surface, etc and finally painted it with flat black paint. That worked the best. It's staying on and even if it does come off it's so thin of a coat it won't cause any problems.
Good luck..
Old Oct 12, 2004 | 05:15 PM
doc_nomad's Avatar
doc_nomad
It should have a couple of holes in the dipstick that the fluid gets stuck in at the proper level, at least on my 94.
Old Oct 12, 2004 | 09:28 PM
mueckster's Avatar
mueckster
The trans dipstick on my '01 has a white plastic end with dimples at the cold and hot range sections. These dimples hold the fluid and makes it easier to see. I don't know if the dipsticks are the same length and could be interchanged.
Old Oct 12, 2004 | 10:35 PM
doc_nomad's Avatar
doc_nomad
My wife's Nissan Xterra has great dip sticks, they are a flexible cable with a serated end to hold the oil. This works great, why cant the US manufacturers catch on, they have only had 40 years.
RedBirdin96
Oct 14, 2016 12:42 PM
rob_jones
Aug 9, 2015 01:11 AM
f250mtnbikr
May 5, 2015 08:58 AM
Austin J.
Sep 11, 2012 06:17 PM
$Simpleman76
2009 - 2014 F150
15
Aug 18, 2010 09:38 PM
