Engine,trans. swap?
Old Oct 11, 2004 | 05:03 PM
nolognom's Avatar
nolognom
Engine,trans. swap?
I have a 56 F-100 with a 352 FE/ 3 spd. MT. I picked up a 351C 2v/ FMX cheap. Wanted an auto. as I live in So. Cal.- frwys. are hell with a stick! Should I stay with the 352 and get a C6?
Old Oct 12, 2004 | 12:16 AM
pcmenten's Avatar
pcmenten
Nice truck.
Question: how is the engine mounted in the chassis. Was it installed using an FE/FT bellhousing with 'ears' that mount to the frame of the truck?
If so, I would recommend getting a FE/FT automatic transmission bellhousing and installing the FMX iron three speed automatic transmission.
Old Oct 14, 2004 | 09:47 AM
nolognom's Avatar
nolognom
Engine swap
Thanks for your suggestion. So you think the FE is better. I don't hear much about FMX's. So wasn't sure.
Old Oct 14, 2004 | 11:00 AM
Randy Jack's Avatar
Randy Jack
I run a 351C (300 hp) with an FMX tranny and really love it. The tranny is very strong and when I had it rebuilt, the guy said that they are also pretty reliable. The C6 is stronger, but might be more than you'll ever need with either motor.
If you're building a cruiser, the deciding factor may well be the tranny mounting that PC talked about.
67 FE Fan
Nov 14, 2014 04:44 PM
Becky_is_a_66
Jun 9, 2013 01:06 AM
BigDawg54
Dec 18, 2009 08:57 PM
joelburn
Sep 1, 2007 10:07 AM
rangoonred67
13
Dec 16, 2003 03:04 AM
