Diff/Transfer Case Play '91 4x4
Old Oct 11, 2004 | 06:38 AM
raleigho's Avatar
raleigho
'91 4x4, 8.8 LS and BW 1356 transfer case. New U-joints, and the drive shaft has about 1"-1 1/2" play in it. That is, it can be rotated back and forth about an inch. Truck has 160,000 miles on it. My question is twofold, the chain in the transfer case, is it difficult to replace? After tightening the pinion nut, could my crush sleeve need replacement? I changed the differential fluid, and the ring and pinion looked okay. There is enough play that it sometimes surges at highway speed, and will do the clunk thing when decelerating.
Old Oct 11, 2004 | 07:40 AM
cmlind's Avatar
cmlind
I am not real familiar with transfer cases, but the chain should be only for the front axle. I think it is all gears going back to the rear axle.
Is the play in the rear end, transfercase or both?
Old Oct 11, 2004 | 06:42 PM
raleigho's Avatar
raleigho
Regarding the chain, that's what I thought also. But it does rotate constantly. The slack is both in the differential and the transfer case. The transmission in neutral and the transfer case in neutral allows you to put your hands on the driveshaft and rotate it 1/2" either way. I'm curious how to remove this slack.
dave91gt
Jun 22, 2009 09:47 AM
dave91gt
Apr 4, 2009 08:37 PM
autx790
1978 - 1996 Big Bronco
Apr 23, 2007 09:54 PM
mgorman
1997 - 2003 F150
Feb 1, 2004 11:38 PM
