Bronco II Ford Bronco II
87 BII
Old Aug 10, 2000 | 08:06 PM
tjd's Avatar
tjd
87 BII
My "REAR ANTILOCK" light on the dash lights up from time to time. Truck runs fine. Any help on what to chase? (Don't have a manual and could not find it in Chiltons). Thanks!
Old Aug 11, 2000 | 09:54 AM
Avanti's Avatar
Avanti
87 BII
You should try flushing out the rear brake system. Clean out your master cylinder and add new fluid.I use an old baby rubber sucker that I only use on brake master cylinders to suck out the old fluid. Bleed the rear brakes untill the fluid looks clean. I did this on my 89 that had the same problem and it cured it.
Old Aug 18, 2000 | 04:28 PM
billboez's Avatar
billboez
87 BII
My '90 Bronco II is doing the same thing. I will try your brake fluid idea. Thanks
Old Sep 2, 2000 | 06:46 AM
dinosaurfan's Avatar
dinosaurfan
87 BII
