New Member!
Old Oct 10, 2004 | 12:31 PM
joyee's Avatar
joyee
I also followed the instructions in manual and could not get it to disable. I also had luck with disable it 2003 towncar but the instructions were different I am going try the Lincoln way with the excursion and see what happens.
Old Oct 10, 2004 | 05:05 PM
heavnbound's Avatar
heavnbound
good luck with this joyee...let me know if you are successful and what you did...this chime is driving me nuts!
Old Oct 10, 2004 | 08:22 PM
Fixxxer14's Avatar
Fixxxer14
I disabled mine with the procedure in the manual :shrug: Keep in mind that you have a time limit on part of it. It took me 3 tries before I got it. Otherwise, you could always unplug it under your seat, but I've heard that may change the way your airbag deploys.
Old Oct 11, 2004 | 12:47 AM
heavnbound's Avatar
heavnbound
Thanks for the reply Fixxer, but I tried using the manual 6 or 7 times and my son (who works in an auto body shop) also tried several times to no avail.
I know about the unplug under the seat too but I don't want anything to risk the airbag (I may not buckle up all the time but I ain't crazy!). I just want to disable the chime so that if my wife drives the Excursion, she won't be fighting with the seat belt!
Maybe someone else will have an idea...I even thought about pulling the fuse to the chime (don't know if that would work or what else would be affected).
Old Oct 11, 2004 | 01:03 AM
jdadamsjr's Avatar
jdadamsjr
Mine worked just like in the manual.....
you could always try the dealer....
tell them the manual procedure didn't fix it.... even try it while in the service bay....
Old Oct 11, 2004 | 04:55 AM
robsmoke's Avatar
robsmoke
seat belt chime
just wait for seat belt chime to start and simply push the red seat belt connector in and it will stop . you must do this at each start up but it will not disable any thing
Old Oct 13, 2004 | 01:29 PM
revandthern's Avatar
revandthern
I had trouble with 2000X, had to shut the door before I started in order for it to disable.
Old Oct 13, 2004 | 01:54 PM
ExcursionUSA's Avatar
ExcursionUSA
Most importantly... welcome to the FTE Forum!
Old Nov 12, 2004 | 03:21 PM
joyee's Avatar
joyee
tried the lincoln way
turn key on wait for seatbelt light to go out buckle and unbuckle belt 9 times wait for light to come back on buckle and unbuckle 1 time light will flash to confirm.this worked on my 03 towncar and 04 excursion
Old Nov 12, 2004 | 04:15 PM
heavnbound's Avatar
heavnbound
Smile Tried the Lincoln Way
Hi Joyee,
Thanks for the info...I'll give this a try. BTW since my last post about this I got ANOTHER Excursion! Now we have twice as much need to disable this damn bell! LOL!
Old Nov 16, 2004 | 02:27 AM
heavnbound's Avatar
heavnbound
Thumbs up
Joyee,
This worked great! Thanks so much - I now have the seat belt chime disabled on both my Excursions! Your method worked flawlessly!
Laserman
Sep 14, 2015 05:54 PM
Eric_F250
18
Jun 3, 2008 04:33 PM
partsBoy
Electrical Systems/Wiring
Oct 1, 2007 07:03 PM
shammee
Modular V10 (6.8l)
May 10, 2004 08:33 PM
RRMike
Dec 5, 2003 11:29 AM
