Bronco II Ford Bronco II
RABS Bronco II
Old Oct 9, 2004 | 08:50 AM
dave milster's Avatar
dave milster
Question RABS Bronco II
Anybody have the correct procedure for bleeding the Rear brakes and RABS controller for an 87 Bronco II?
Does it require a special tool? and what does the tool do and where does it go?
Old Oct 9, 2004 | 05:48 PM
Ken00's Avatar
Ken00
I don't know of anything special as far as tools or procedure.
Old Oct 9, 2004 | 05:51 PM
BroncII's Avatar
BroncII
87 BII Brakes
Pretty straight forward. Keep reservoir full at all times. Have assistant pump brakes while you bleed each wheel starting from the farthest from the master cylinder. Use a length of rubber hose attached to the bleeder valve at one end and the other end submerged in brake fluid. Pump until no bubbles. Same for the preasure diierential valve. After you are done, if the warning light is still on you must centralize the preasure differential valve. Turn on the ignition to on, depress the brake pedal and the peasure switch should center itself causing the brake warning light to go out. Turn off the ignition switch and test brakes. No special tools, you should have a bleeder valve tool just to make it easier......
Hope this helps.
Good luck!
Old Oct 9, 2004 | 10:13 PM
dave milster
Should the RABS proportioning valve be bled first or last?
Old Oct 10, 2004 | 08:03 PM
Ken00's Avatar
Ken00
I would just bleed them in the normal order and not worry about the valve.
Old Oct 12, 2004 | 05:38 PM
BroncII's Avatar
BroncII
Thats correct. Bleed the valve only if air gets trapped after it is has been replaced or system won't equalize and center up.
Good luck!
fordguy4life
Aerostar
23
Dec 2, 2025 09:20 PM
rlvbronco
1978 - 1996 Big Bronco
Sep 14, 2016 05:12 PM
jetdoc
Oct 20, 2015 08:12 AM
SteveL53
1997 - 2003 F150
Sep 18, 2014 06:20 AM
