Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Copper pipe for air lines.
Old Oct 9, 2004 | 08:46 AM
stryder's Avatar
stryder
Is there any reasons against using soldiered copper pipe for compressed air lines? I've being using them for years and have had no problems. I was thumbing through my owners manual for my Quincy the other morning (all this talk of compressors made me have to get it out) and it says not to use piping with leaded joints. It doesnt give any reasons and I can find any on the net. There are a lot of shops I know of that use copper and havent heard of any problems either. Can someone enlighten?
Stryder
Old Oct 9, 2004 | 10:13 AM
Steina's Avatar
Steina
CO River Rat
Stryder -
Supposedly, pulse vibration will eventually cause the copper and/or soldered joints to fail. Like you, I've seen many copper installations with no problems YET.
Steve
Old Oct 9, 2004 | 10:18 AM
ivanribic's Avatar
ivanribic
I think the big trick is using a section of hose from your compressor to your piping to absorb the vibrations caused by the compressor. If you do that it shouldn't be a problem.
Old Oct 9, 2004 | 10:29 AM
Steina's Avatar
Steina
CO River Rat
Ivan -
Good point about using a flex line between the compressor and hard pipe. I don't know if the installs I've seen had this feature, but if so that's probably why they've been trouble-free.
Steve
Old Oct 9, 2004 | 01:26 PM
Mike W's Avatar
Mike W
I once had a 100' copper line out to the back yard. I had to resolder a couple of leaks when I first put in it. Other then that, no problems.
Old Oct 9, 2004 | 04:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Look thru some of the old posts here on shop air systems, check the archives too. There were a few posts on the specs that copper air lines had to meet for compressed air. I am not sure if the standard water type copper pipe is OK for compressed air service. It may need special pipe and special solder or brazing etc. I just use iron pipe. I prefer galvanized pipe but black pipe seems to be the preferred material.
Old Oct 10, 2004 | 03:56 PM
mantta's Avatar
mantta
If you silver solder the joints on copper pipe there is no reason it would not be okay. Large air conditioning and refrigeration systems use copper pipe and have much higher pressures than air systems. The joints are silver soldered.
Old Oct 10, 2004 | 04:39 PM
Greg 79 f150's Avatar
Greg 79 f150
I have never heard of copper being a problem, other than the possibility of soldering flux contamination in sensitive air usage situations like say, air lines for auto spray painting. The pressure rating on any copper used should be rated more than the air compressor maximum output, of course. And it is always best to use a flexible metal hose connection from the a/c tank oulet to the first piece of piping downstream anyway. I piped my garage in with 3/4 in . black pipe because I did not want to use a torch flame against the wood members, and it has served me well. jmo
Old Oct 10, 2004 | 07:02 PM
kotzy's Avatar
kotzy
I don't see a problem with copper, has anyone heard of any plastic being used?
Old Oct 10, 2004 | 07:35 PM
stryder's Avatar
stryder
DO NOT USE PLASTIC!!!
There are MANY threads concerning PVC usage. IT IS NOT RATED FOR COMPRESSED AIR. It can and WILL explode once it gets brittle and cold.
Stryder
jcowan90501's Avatar
jcowan90501
Don't use plastic (PVC...)
Hi,
If you do a google search on pvc (which I'm assuming you mean
when you talk about plastic pipes) you'll find some OSHA and
building code sites specifically calling PVC unacceptable in
pressurized gas lines. The problem is a compressed gas
contains alot of energy and it there is a crack/split in the
PVC it'll shatter and the shards will become projectiles.
Kind of like your own little hand granade.
I've seen it used in shops but the code said it had to be
encased so the shards couldn't escape.
thanks
jim cowan
Old Oct 10, 2004 | 08:41 PM
super440's Avatar
super440
Our shop has solid copper straight off the compressor, never had a problem. And we run 220psi due to long runs of pipe all the way around the shop, or maybe because nobody adjusts the cut-off.
Old Oct 10, 2004 | 09:16 PM
mech2161's Avatar
mech2161
My shop has SCH40 plastic. I've been using it for six years. Some is even in the attic, gets real hot. I think the new plastic also has a temp rating for hot water that gives it a higher PSI. The PSI rating is marked on it. Make sure you use the precleaner before the glue.
Old Oct 10, 2004 | 09:51 PM
DW2455's Avatar
DW2455
I've seen PVC sch 40 and sch 80 used in shops before. DW
Old Oct 10, 2004 | 10:03 PM
68torino's Avatar
68torino
We use basic black iron pipe, threaded fittings with pipe dope at work. Two 75hp twin screw Quincys. Cheap pipe to buy and lasts forever.
