Sagging Front Bumper- Frowning?
Old Oct 9, 2004 | 12:17 AM
1990F250LB's Avatar
1990F250LB
OK, this seems to be somewhat common. I have a 1996 F250 PSD, and the front bumper is sagging at the tips, kind of like a frown.
I've looked at the bumper - seems normal. All the hardware seems normal - but there is a sag.
My truck is certainly not perfect, but is this something that can be fixed? Maybe with a jack, heavy ropes, or a big boot?
Thanks.
JC
Old Oct 9, 2004 | 08:03 AM
frederic's Avatar
frederic
Behind the bumper, attaching it to the frame stubs, are two metal plates that hold the bumper on. They are either loose, or bent, and need to be replaced. Its possible the frame stubs are bent too, but unless you hit something thats unlikely. The brackets are available from Ford still, and just a few dollars (like $30 or so, I forget).
Old Oct 9, 2004 | 08:20 PM
aikigod's Avatar
aikigod
For a real cheap fix, I used a few washers on the upper bolts between the bumper and bumper bracket to kinda shimmy mine out. Fixed the frown; it now looks as straight as it should. Couldn't stand the look on my truck whenever I jumped into her...
Old Oct 11, 2004 | 12:00 AM
Jakeman68's Avatar
Jakeman68
I took the bumper off of mine and used a big pair of channel-locks and bent the bracket a little more forward on the top. (after removing the bumper of course). I know it sounds kinda Arkie but it worked for me.
Old Oct 11, 2004 | 02:48 PM
Jarrett T's Avatar
Jarrett T
I just loosened the bolts. straightened it up and it was fine. Used an impact to break those bolts/nuts loose.
Old Oct 11, 2004 | 08:38 PM
stang8893's Avatar
stang8893
My dad hit my bumper pretty hard and one side is sagging. I've looked at junk yards in the area and they don't have one. I don't want to pay 400$ for a new one. The sagging corner is a pet peeve of mine and i hate seeing it. Anybody know a cheaper place to get one other than a car dealer and e-bay?
Old Oct 11, 2004 | 09:34 PM
frederic's Avatar
frederic
If you're in or near central NJ, I have one from a 93 sitting on the ground. Chrome is okay with one minor dent (and its minor).
Old Oct 12, 2004 | 09:52 AM
Fordfanz's Avatar
Fordfanz
I also see bumpers on Ebay for 30 bucks all t he time .Hope this Helps
96f150
1997 - 2003 F150
13
Dec 23, 2016 04:25 PM
D11Dozer
Mar 8, 2016 06:13 AM
Papas66
May 29, 2014 08:54 PM
SethMansel
May 2, 2013 01:49 PM
mossyoakford96
Apr 24, 2012 12:21 AM
