Starter Noise Question
Old Oct 8, 2004 | 12:30 PM
waltp's Avatar
waltp
Question Starter Noise Question
95 F150 w/ 5.0, Automatic. Changed out starter for a rebuilt about 6 months ago. Recently, have been getting grinding noise every 3rd or 4th start. What gives? Ford doesn't need starter shims like my old Chevys did.
Could it be the "Bendix" isn't always disengaging, or should I start thinking about inspecting my Flywheel for damaged teeth? Motor has about 175K and has never been touched. Plan to pull off starter this weekend. Where's the flywheel inspection port on this motor?
An aside - my oil pan is on its way out and had been leaking pretty badly until I did a temporary patch with J-B Weld - starter was well oiled too. Could this have any effect or just a coincidence?
Old Oct 8, 2004 | 10:07 PM
smoke n tires's Avatar
smoke n tires
my friend had to use shims in his ford starter. its uncommon, but a possibility. try one and see if it helps...
jamesh23
26
Jul 19, 2016 10:47 AM
dawson_815
Jul 15, 2016 08:49 AM
Green Streak
Feb 5, 2007 07:23 PM
nairod
Electrical Systems/Wiring
15
Nov 7, 2006 08:13 PM
88f150*300
1997 - 2003 F150
Mar 21, 2004 03:06 PM
