351m swap error
Old Feb 5, 2007 | 05:39 PM
Green Streak's Avatar
Green Streak
351m swap error
I swapped a 300-6 out of my 78 f250 4 speed 4x4 and installed a 351m which had been hooked up to an automatic. I obtained the bell housing, clutch, flywheel from the wreckers and all bolted up just fine...almost. The starter just barely reaches the flywheel and only catches the very edge. I have the correct starter. My question is, could there be a spacer left on the motor from its automatic days keeping the flywheel out further from the starter than it should be? Incidentally, the truck started up fine, clutch worked great all bolts properly located no problem other than the starter barely catches, and now it is wearing away the teeth on the starter on the last 1/16". I hope this is clear I don't have much time to get this done and I was wondering if there is anything specific I should be looking for. It has been suggested that I grind away the plate between the tranny and engine to allow the starter a little more inward travel but I prefer not to. Any suggestions would be greatly appreciated.
Thanks in advance Greg
Old Feb 5, 2007 | 06:10 PM
mhg's Avatar
mhg
I have found in the past that there is a differance between auto and
standard starters
have your parts man pull for both and check for any differance
Old Feb 5, 2007 | 07:23 PM
Green Streak
Thanks for the thought but it is a standard starter, I have tried two different ones with same result
NP435Bronco
15
Dec 1, 2025 09:45 AM
ArdWrknTrk
130
May 21, 2021 11:45 PM
jamesh23
26
Jul 19, 2016 10:47 AM
stanky
Engine Swaps
Jun 13, 2004 07:28 AM
j.foster62
Jan 6, 2004 09:06 PM
