2000 explorer limited electrical problem
Old Oct 8, 2004 | 07:19 AM
dlm9591's Avatar
dlm9591
After starting with doors closed, the door ajar light stays on with all doors closed and double checked and the dash lights look to be about half of the correct brightness as found in the radio and the doors do not lock automatically when put into gear.
Old Oct 8, 2004 | 07:23 AM
98txexplorer's Avatar
98txexplorer
spray some penetrating oil into the latch assembly on all the doors. the switch for the door ajar is built into the latch assembly and from moisture build up and such will become stuck. just spray a few times and close and open the door a few times and that should solve your problems
Old Oct 9, 2004 | 05:54 PM
ArkieRebel's Avatar
ArkieRebel
Probably your door ajar switches. Those are problematic on that year Explorer and Ranger.
DarwinOz
1997 - 2003 F150
Sep 30, 2013 09:20 PM
Jamie Arceneaux
Mar 16, 2013 09:05 AM
edub32
Sep 5, 2008 08:36 AM
neilc88
Dec 8, 2007 11:55 PM
rosa70
Feb 19, 2005 11:04 PM
