95 Explorer High Rear Tail Light
Old Oct 8, 2004 | 07:02 AM
VTBrian's Avatar
VTBrian
Question 95 Explorer High Rear Tail Light
Hey folks. My rear tail light above the rear window burned out and I am quite perplexed as to how replace it. I have removed the interior piece to get access to some screws, and by opening up the window, there appear to be some rivets binding this to the flashing. Does one ultimately have to remove the door altogether, or is there something else I am missing. I'd appreciate any suggestions if you have been through this before.
Thanks, Brian
Old Oct 8, 2004 | 07:27 AM
98txexplorer's Avatar
98txexplorer
havent replaced this yet but from my understanding from other posts, i believe you have to drill out the rivets in order the replace the light. its a high intensity led bar with a transformer near it that produces quite a bit of power from what i heard, do a search for your problem and you should find more info, sorry i couldnt be any further help.
Old Oct 9, 2004 | 05:33 AM
marragtop's Avatar
marragtop
Before you do all that, make sure you are getting current to it the assembly.
Mike
Old Oct 9, 2004 | 01:05 PM
VTBrian's Avatar
VTBrian
thanks
Many thanks to marragtop and 98txexplorer for your comments. My lamp was waterlogged, so I suspect that somehow I must have shorted out over time. I wonder how long ago that it happened. I went through my repair methodology so perhaps that helps for others. See Cali-gal's original thread.
Cheers
Brian
Brian Skinner
Aerostar
13
Jan 11, 2015 04:01 PM
brian Felts
Aug 1, 2010 07:52 PM
bhowe2
Jan 5, 2005 11:45 PM
brian's79ford
15
Apr 28, 2004 09:23 AM
video
1978 - 1996 Big Bronco
Nov 3, 2002 06:35 PM
