Bronco II Ford Bronco II
what all could be wrong?
Old Apr 10, 2001 | 12:39 PM
tcbradbury98's Avatar
tcbradbury98
I have an 87 BII with electric locks, and the only lock that doesn't work is the passenger side, what exactly is inside the door that controls the lock,some sort of actuator?
Old Apr 10, 2001 | 11:25 PM
babybroncoii's Avatar
babybroncoii
the actuator should be mounted on the very bottom of the door on the side closest to the back. it should have a metal pole running up to your lock. my actuator went bad, and since i work at circuit city, i just took it in and i installed an alpine actuator, which doesn't even require the removal of the old actuator. it just mounts about halfway up the door and helps out the factory actuator. take it in and see if they will take a look at it for you, or just go in and do it yourself. it mounts a little cockeyed because of the shape of the door on the inside, but it still works. good luck
Old Apr 11, 2001 | 09:56 AM
jimmyfoddrell's Avatar
jimmyfoddrell
Memphis_Sean
Jun 7, 2014 11:13 PM
jo15765
Sep 6, 2013 10:15 PM
MUDLIZARD
Nov 28, 2011 01:21 PM
crazer42
Mar 1, 2009 09:41 PM
