Help with pinging 460
Old Oct 31, 2004 | 10:43 PM
airharley's Avatar
airharley
You can go to www.tires.com They should have a speedo calulator that takes rpm, rearend gears, and tire diameter into concideration. Or was that here in the tech section all the way at the bottom?
Old Oct 31, 2004 | 11:02 PM
monsterbaby's Avatar
monsterbaby
Originally Posted by 53wa2fl
Anyone got that tachometer calculator? I want to keep the RPM's at aropund 2000-2200 with 33 inch tires and a C-6 transmission....what gears do I need?
you didn't mention what speed you want to turn those rpms at, but assuming 65mph, you would need 3.32 gears, and you can play with a several good calculators at 4lo.com also.
Old Oct 31, 2004 | 11:58 PM
tmyers's Avatar
tmyers
The D2 heads are the problem here and there is almost nothing you can do with them. If you have been thinking aluminum now is the time. I would go with Trick Flow because they have a 92cc combustion chamber if I remember right and flow great right out of the box. This way you will not need to change anything else.
vtjvt
Sep 27, 2015 02:32 PM
XLT2.5L
1983 - 2012 Ranger & B-Series
25
Aug 24, 2009 07:08 AM
david00f150
Jun 28, 2009 08:11 PM
jbabbler
3.0L V6
Jan 7, 2005 10:02 PM
jopey
19
Aug 26, 2001 01:22 AM
